    Help! Interior scenes - lights too bright or room too dark
    renderpluginsextensions
    4 Posts 4 Posters 4.7k Views 4 Watching
    • D
      dingobruce
      I've been having some issues for a long time with interior scenes and finally thought it was time to ask on here for your advice on interior lighting. I find it impossible to achieve good overall lighting without having VRAY lights burning out.
      See these two attached examples.
      Lights in Scene:
      Strip light: VRay Rectangle Light (intensity 20 (scalar))
      Pool Lights: 2 X IES (power 50,000)
      The first is rendered with the following:
      Shutter Speed: 20
      F Number: 8
      Film ISO: 100
      Too dark
      This image has nice lighting, but the overall image is too dark.
      The second is rendered with the following:
      Shutter Speed: 20
      F Number: 8
      Film ISO: 400
      Too light
      The overall lighting is much better but the lights are burnt out.
      How do I achieve balance! Look forward to advice from you guys!
      Thanks,
      Dingo Bruce.
      • V
        valerostudio
        There is no magic button. You have to light a scene the way you would in real life. Fixtures with IES lights, windows letting in sunlight, maybe you even setup a few rectangular lights behind your camera as additional lighting, the same way a photographer would.
        http://www.popphoto.com/how-to/2013/03/how-to-mix-light-sources-to-warm-interior-photo
        http://www.cg-blog.com/index.php/2012/09/04/living-light-balance.htm
        • kimi kimiK
          kimi kimi
          I think if you go to Color mapping, choose HSV Exponential, you can play a little bit with dark and bright multiplier to get a better result. And there is always Photoshop to assist you further.
          • HornOxxH
            HornOxx
            πŸ˜‰
            I like the clear and simple way how you have expressed this.
            Your three sentences should be the introduction for each lighting chapter of any Render Tool.
            However, I would like such a "magic button"
            never trust a skinny cook
