    No internal shodows
    9 Posts 4 Posters 613 Views 4 Watching
      Bruce Watt
      Can anyone help me out please. For some reason I can not get any shadows to show up internally. Please see attached. Any ideas as to what I am doing wrong here?
      No internalshadows screen shotno internal shadows skp file
      SKUP PRO 2021 latest version / update
      Windows 10 Pro
      Dell Alienware Aurora R10 AMD
      AMD Ryzen™ 9 3900X
      NVIDIA® GeForce RTX™ 2080 Ti 11GB GDDR6
      • K Offline
        kaas
        your file opens fine for me. All shadows are as they should be. Have you tried exploding the group and re-grouping?
          slbaumgartner
          Open the Shadows window and check the box "On Faces".
            Bruce Watt
            Thanks "on faces" is grayed out, how do I make it active?
            Windows 10 Pro
            AMD Ryzen™ 9 3900X
              Bruce Watt
              ok something is definitively screwy.
              I have turned off "Use hardware acceleration" and I have shadow back again and "on faces" box is now select-able again.
              Saved file and reopened again, shadows are very slow. Selected "Use hardware acceleration" and again to turn on, saved file and close.
              Reopened file and all is well again. odd, perhaps it is the windows 10, but I dont know.
              Thank for your help.
              Windows 10 Pro
              AMD Ryzen™ 9 3900X
              • K Offline
                kaas
                In your sig you write 'AMD Radeon'. If I remember well, the Radeon drivers caused issues with SketchUp before. Maybe their openGl drivers for win10 are still a bit ...
                  Shadows... Use Sun For Shading ??
                    Bruce Watt
                    yes you would think so, The check box does not seem to make any difference here. (However shadows is working currently)
                    Use sun
                    No use sun
                    What is this check box for anyway?
                    Windows 10 Pro
                    AMD Ryzen™ 9 3900X
                      slbaumgartner
                      Normally SketchUp shades surfaces as if the light source is at the camera. It does not cause shadows to be cast, regardless of settings. The "use sun for shading" instead shades surfaces as if the only light source is at the sun position. When shadows are displayed, this can produce a more realistic look because you don't have shading from one light source and shadows from a different one.
