    Section cuts
    5 Posts 4 Posters 568 Views 4 Watching
    • O
      Obleyo
      My question is:
      Is there a plug-in or some other way to turn a section cut line into an actual, selectable line? I would like to take a topography line from a section cut and copy it without having to trace over it.
      I'm sure I'm probably just missing something very simple to do this, no?
      Please advise.
      Thanks,
      Joel
        Yes. You are missing something very simple. Right click on the section plane and choose Create group from slice. No plugin required.
        • TIGT
          Select the Section-Plane.
          Use the context-menu > Create Group from Slice...
          Or to add faces, consider using my own SectionCutFace tool with settings to keep/show edges... or look at the even more comprehensive Skalp...
          Edit the resultant group to access the new edges...
          [I already gave this reply to you earlier on another forum... next time it might be best to ask here, or there, to avoid duplication...]
          • JQLJ
            JQL
            Tig,
            You should save that response as a template. It's as streamlined as can be and fits perfectly for a lot of section related stuff...
            www.casca.pt
            Visit us on facebook!
            • JQLJ
              JQL
              ... duplicate
              www.casca.pt
