    [REQ] Open and close all nested groups in selection
    19 Posts 7 Posters 1.4k Views 7 Watching
    • PixeroP Offline
      Pixero
      As a way of automating the process from here:
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=61842#p565790
      Can someone make a script that open and close all nested groups in a selection?
      • tt_suT Offline
        tt_su
        From what I can gather this action is done in order to make groups unique - for that there is group.make_unique. That appears to be a more correct way to address it - you are after all looking for unique instances.
        Not saying that being able to open an instance wouldn't be useful. (There is a way to close instances already, having a way to open would be a nice symmetry.)
        • JQLJ Offline
          JQL
          That would also be handy for Revit DWG import, as it seems in this post here:
          http://sketchucation.com/forums/viewtopic.php?f=11%26amp;t=61846
          User and me were misguided by the fact that groups even call themselves components in that situation. I hadn't noticed that before and even if I was aware of groups behaving like components, I would never get so far as thinking the bastards would use their name too...
          Another thing that is related to this, is that if you want to edit the name of a copy of an unedited group. Because of some conflict with existing component you always get a popup message saying you can't do that for components though right after that message you can after all. Very annoying and time consuming. (Now that I think of it I haven't seen that message that much lately... something fixed?)
          www.casca.pt
          Visit us on facebook!
          • PixeroP Offline
            Pixero
            Would this work?
            selection=Sketchup.active_model.selection
            selection.grep(Sketchup;;Group) {|group| group.make_unique }
              After the selection grep you need a .each ...
              Sketchup.active_model.selection.grep(Sketchup::Group)**.each**{|g| g.make_unique }
              or to do it to ALL groups do this ...
              Sketchup.active_model.definitions.select{|d| d.group? }.each{|g| g.make_unique }
              • PixeroP Offline
                Pixero
                Thanks.
                • KrisidiousK Offline
                  Krisidious
                  I use the backout plugin to exit nested groups...
                  By: Kristoff Rand
                  • PixeroP Offline
                    Pixero
                    Hmm...I tried it exactly as you wrote but it didn't work. πŸ˜•
                    But, if I manually double click to open the groups and then close them and run the hide intersecting edges script it works.
                    Any ideas what could be missing?
                    I don't get any error messages in the console.
                      If you use this line in the Ruby Console what is listed ?
                      gps = Sketchup.active_model.selection.grep(Sketchup::Group)
                      If it's a list of selected groups, then what happens with this ?
                      gps.each{|g| g.make_unique if g.entities.parent.instances[1] }
                      There's no need to use 'make_unique' unless there are multiple copies ??
                      • PixeroP Offline
                        Pixero
                        That seem to work.
                        Again, thanks!
                        • PixeroP Offline
                          Pixero
                          I spoke to soon. It doesn't work if there are nested groups.
                          • sdmitchS Offline
                            sdmitch
                            I knew I had seen a similar discussion some where. This might be what you are looking for.
                            http://sketchucation.com/forums/viewtopic.php?p=346107#p346107
                            I think there is a newer version in the plugin store.
                            Never mind, as written, the plugin fails with nested groups.
                            I think it would be an easy fix.
                            http://sdmitch.blogspot.com/
                            • tt_suT Offline
                              tt_su
                              .grep takes a block which it will invoke on all matched elements. On large sets it's somewhat faster.
                                CAUL
                                The code below makes a recursive traversal through nested groups. I will add an UI to the hide overlapping extension where make_unique is an option.
                                  def self.makeUnique(ents)
                                    ents.grep(Sketchup;;Group).each { |g|
                                      g.make_unique
                                      makeUnique(g.entities)
                                  makeUnique(Sketchup.active_model.selection)
                                • PixeroP Offline
                                  Pixero
                                  I tried your code but it didn't work with nested groups either. 😞
                                    CAUL
                                    I think there are two issues here.
                                    1. HideOverlappingGeometry does not compare groups within a common top group. So in your example, the 4 boxes within a group will not be compared with each other, they will however be compared to the 4 boxes in the other group. That's just a choice I made in the extension that reflects the way I use the script. If you want to hide the seams between the groups within a group you have to enter the group and select all groups within and then run the script. I think I will add an option to the extension so that is also compares stuff within the same nesting.
                                    2. I don't quite see why the provided code doesn't work in your example. I tried with a similar example and the groups all became unique. Do you have a sample model?
                                    • PixeroP Offline
                                      Pixero
                                      Here is a simple example file.
                                      A real life model would probably have more nested levels.
                                      NestedGroups.skp
                                        CAUL
                                        I get the result below (and the nested groups also becomes unique):
                                        Before
                                        After
                                        • PixeroP Offline
                                          Pixero
                                          Ok, so then it's a matter of you implementing the compare overlapping edges in nested groups?
