    [REQ] Open and close all nested groups in selection
    19 Posts 7 Posters 2.0k Views 7 Watching
    • PixeroP
      Pixero
      That seem to work.
      Again, thanks!
      • PixeroP
        Pixero
        I spoke to soon. It doesn't work if there are nested groups.
        • sdmitchS
          sdmitch
          I knew I had seen a similar discussion some where. This might be what you are looking for.
          404 Not Found
          (sketchucation.com)
          I think there is a newer version in the plugin store.
          Never mind, as written, the plugin fails with nested groups.
          I think it would be an easy fix.
          http://sdmitch.blogspot.com/
          • tt_suT
            tt_su
            @tig said:
            After the selection grep you need a .each ...
            .grep takes a block which it will invoke on all matched elements. On large sets it's somewhat faster.
            • C
              CAUL
              @pixero said:
              As a way of automating the process from here:
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=61842#p565790
              Can someone make a script that open and close all nested groups in a selection?
              The code below makes a recursive traversal through nested groups. I will add an UI to the hide overlapping extension where make_unique is an option.
                def self.makeUnique(ents)
                  ents.grep(Sketchup;;Group).each { |g|
                    g.make_unique
                    makeUnique(g.entities)
                makeUnique(Sketchup.active_model.selection)
              • PixeroP
                Pixero
                I tried your code but it didn't work with nested groups either. 😞
                • C
                  CAUL
                  I think there are two issues here.
                  1. HideOverlappingGeometry does not compare groups within a common top group. So in your example, the 4 boxes within a group will not be compared with each other, they will however be compared to the 4 boxes in the other group. That's just a choice I made in the extension that reflects the way I use the script. If you want to hide the seams between the groups within a group you have to enter the group and select all groups within and then run the script. I think I will add an option to the extension so that is also compares stuff within the same nesting.
                  2. I don't quite see why the provided code doesn't work in your example. I tried with a similar example and the groups all became unique. Do you have a sample model?
                  • PixeroP
                    Pixero
                    Here is a simple example file.
                    A real life model would probably have more nested levels.
                    NestedGroups.skp
                    • C
                      CAUL
                      I get the result below (and the nested groups also becomes unique):
                      Before
                      After
                      • PixeroP
                        Pixero
                        Ok, so then it's a matter of you implementing the compare overlapping edges in nested groups?
