    [REQ] Open and close all nested groups in selection
    19 Posts 7 Posters 1.6k Views 7 Watching
    • KrisidiousK Offline
      Krisidious
      I use the backout plugin to exit nested groups...
      By: Kristoff Rand
      • PixeroP Offline
        Pixero
        Hmm...I tried it exactly as you wrote but it didn't work. πŸ˜•
        But, if I manually double click to open the groups and then close them and run the hide intersecting edges script it works.
        Any ideas what could be missing?
        I don't get any error messages in the console.
          If you use this line in the Ruby Console what is listed ?
          gps = Sketchup.active_model.selection.grep(Sketchup::Group)
          If it's a list of selected groups, then what happens with this ?
          gps.each{|g| g.make_unique if g.entities.parent.instances[1] }
          There's no need to use 'make_unique' unless there are multiple copies ??
          • PixeroP Offline
            Pixero
            That seem to work.
            Again, thanks!
            • PixeroP Offline
              Pixero
              I spoke to soon. It doesn't work if there are nested groups.
              • sdmitchS Offline
                sdmitch
                I knew I had seen a similar discussion some where. This might be what you are looking for.
                http://sketchucation.com/forums/viewtopic.php?p=346107#p346107
                I think there is a newer version in the plugin store.
                Never mind, as written, the plugin fails with nested groups.
                I think it would be an easy fix.
                http://sdmitch.blogspot.com/
                • tt_suT Offline
                  tt_su
                  @tig said:
                  After the selection grep you need a .each ...
                  .grep takes a block which it will invoke on all matched elements. On large sets it's somewhat faster.
                    CAUL
                    @pixero said:
                    As a way of automating the process from here:
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=61842#p565790
                    Can someone make a script that open and close all nested groups in a selection?
                    The code below makes a recursive traversal through nested groups. I will add an UI to the hide overlapping extension where make_unique is an option.
                      def self.makeUnique(ents)
                        ents.grep(Sketchup;;Group).each { |g|
                          g.make_unique
                          makeUnique(g.entities)
                      makeUnique(Sketchup.active_model.selection)
                    • PixeroP Offline
                      Pixero
                      I tried your code but it didn't work with nested groups either. 😞
                        CAUL
                        I think there are two issues here.
                        1. HideOverlappingGeometry does not compare groups within a common top group. So in your example, the 4 boxes within a group will not be compared with each other, they will however be compared to the 4 boxes in the other group. That's just a choice I made in the extension that reflects the way I use the script. If you want to hide the seams between the groups within a group you have to enter the group and select all groups within and then run the script. I think I will add an option to the extension so that is also compares stuff within the same nesting.
                        2. I don't quite see why the provided code doesn't work in your example. I tried with a similar example and the groups all became unique. Do you have a sample model?
                        • PixeroP Offline
                          Pixero
                          Here is a simple example file.
                          A real life model would probably have more nested levels.
                          NestedGroups.skp
                            CAUL
                            I get the result below (and the nested groups also becomes unique):
                            Before
                            After
                            • PixeroP Offline
                              Pixero
                              Ok, so then it's a matter of you implementing the compare overlapping edges in nested groups?
