    [REQ] Fragmenting script
    20 Posts 6 Posters 1.6k Views 6 Watching
    • soloS Offline
      solo
      Would it be possible to create a script that can fragment geometry something like this: http://www.scriptspot.com/3ds-max/plugins/vorofrag
      Or take a basic shape and fragment it into 3D bricks or random shaped stones like this:
      Adam Muir model
      Obviously this does not need to be a free script, everyone needs to eat, I will be willing to pay.
      http://www.solos-art.com
      • soloS Offline
        solo
        @solo said:
        I see Fredo was playing with the concept, but not sure if he completed it yet.
          This one ?
          Make some Zorro2 lines or Voronoi on your volume before if necessary!
            After a segmentation
              ExplodedView after some fragmentations πŸ˜‰
              You have also that
              Steping Stones By Sdmitch
              Align and distribute by Sdmitch! πŸ˜‰
              Make 2 or more levels of "Thickness"
              http://www.3dsaloon.fr/phpbb3/download/file.php?id=4080&mode=view
                When you have some different solids with any method you can also use
                SketchyPhysics for falling them inside a "curvated box" ! πŸ˜„
                  You can also use this free powerful one then import the result inside SU !
                  ManifoldLAB 😎 (Wings3D is inside)
                  Make a general cut following your curvated box on any voronoΓ― stones! πŸ˜‰
                  • K Offline
                    KENTUCKY
                    http://oob.duckdns.org/
                    here is the link to a plugin I stumbled upon a few weeks back.
                    I haven't tried it but the youtube video looked promising
                    • soloS Offline
                      solo
                      Too limited, not well supported and for what it does Floor generator does better and is free
                        Did you look at Blenders Cell Fracture add on?
                        • soloS Offline
                          solo
                          I have, and even did an animation with it, however I really want an SU solution as what I need requires a ton of models and the back and forth is just way too much work.
                            Only other thing that I remember was this tool Mike mentioned a while ago
                            http://www.intresto.com.au
                            Or PM Fredo. I'm sure he has something worth testing.
                            • soloS Offline
                              solo
                              I saw that, not much info there besides it solving real world rocks.
                              I was hoping Fredo read my post and chimed in actually, I hate pestering these guys as they could be busy.
                                TIGs cut to plane ran a few time can do a type of fragmenting.
                                It's just slow to do.
                                    Perhaps this ?
                                    http://sketchucation.com/forums/viewtopic.php?p=564982#p564982
                                    http://sketchucation.com/pluginstore?pln=TIG_Fracture
                                      @TIG
                                      I have some fracture tool code.
                                      Not sure where I got it. But it looks like Cut To Plane but bastardised
                                        @rich o brien said:
                                        @TIG
                                        I think I gave something to you several years ago !
                                        But I never released v1.0 πŸ˜’
                                        This is now v2.0, which includes settings for Iterations 1-10 and Size % 1-50, and a final optional Explode.
                                        It also uses a simpler/faster algorithm for splitting, and by limiting any piece to at least 1% of the original part, then there is now much less likelihood of a split-off piece not being solid [although it also has some code to try and fix any that the 'subtract' tool leaves half-baked]...
                                          That s nice upgrade.
                                          Thanks.
                                          • F Offline
                                            faust07
                                            As pilou mentioned - SketchyPhysics - with unexpected results... not really for natural stonewalls. But it's worth to try...
                                            Splittest 2 - unexpected
