    [REQ] Fragmenting script
    20 Posts 6 Posters 1.3k Views 6 Watching
    • soloS Offline
      Would it be possible to create a script that can fragment geometry something like this: http://www.scriptspot.com/3ds-max/plugins/vorofrag
      Or take a basic shape and fragment it into 3D bricks or random shaped stones like this:
      Adam Muir model
      Obviously this does not need to be a free script, everyone needs to eat, I will be willing to pay.
      • soloS Offline
        @solo said:
        I see Fredo was playing with the concept, but not sure if he completed it yet.
          This one ?
          Make some Zorro2 lines or Voronoi on your volume before if necessary!
            After a segmentation
              ExplodedView after some fragmentations πŸ˜‰
              You have also that
              Steping Stones By Sdmitch
              Align and distribute by Sdmitch! πŸ˜‰
              Make 2 or more levels of "Thickness"
              http://www.3dsaloon.fr/phpbb3/download/file.php?id=4080&mode=view
                When you have some different solids with any method you can also use
                SketchyPhysics for falling them inside a "curvated box" ! πŸ˜„
                  You can also use this free powerful one then import the result inside SU !
                  ManifoldLAB 😎 (Wings3D is inside)
                  Make a general cut following your curvated box on any voronoΓ― stones! πŸ˜‰
                    KENTUCKY
                    http://oob.duckdns.org/
                    here is the link to a plugin I stumbled upon a few weeks back.
                    I haven't tried it but the youtube video looked promising
                    • soloS Offline
                      Too limited, not well supported and for what it does Floor generator does better and is free
                        Did you look at Blenders Cell Fracture add on?
                        • soloS Offline
                          I have, and even did an animation with it, however I really want an SU solution as what I need requires a ton of models and the back and forth is just way too much work.
                            Only other thing that I remember was this tool Mike mentioned a while ago
                            Landscape design software | shape optimisation | mosaics, paving, tiling, cladding | cutting and packing
                            Rocksolver solves the jigsaw puzzle and shows you where to put each stone, tile or component. Beta ready to optimize your puzzle.
                            (www.intresto.com.au)
                            Or PM Fredo. I'm sure he has something worth testing.
                            • soloS Offline
                              I saw that, not much info there besides it solving real world rocks.
                              I was hoping Fredo read my post and chimed in actually, I hate pestering these guys as they could be busy.
                                TIGs cut to plane ran a few time can do a type of fragmenting.
                                It's just slow to do.
                                    Perhaps this ?
                                    http://sketchucation.com/forums/viewtopic.php?p=564982#p564982
                                    http://sketchucation.com/pluginstore?pln=TIG_Fracture
                                      @TIG
                                      I have some fracture tool code.
                                      Not sure where I got it. But it looks like Cut To Plane but bastardised
                                        @rich o brien said:
                                        @TIG
                                        I think I gave something to you several years ago !
                                        But I never released v1.0 πŸ˜’
                                        This is now v2.0, which includes settings for Iterations 1-10 and Size % 1-50, and a final optional Explode.
                                        It also uses a simpler/faster algorithm for splitting, and by limiting any piece to at least 1% of the original part, then there is now much less likelihood of a split-off piece not being solid [although it also has some code to try and fix any that the 'subtract' tool leaves half-baked]...
                                          That s nice upgrade.
                                          Thanks.
                                          • F Offline
                                            faust07
                                            As pilou mentioned - SketchyPhysics - with unexpected results... not really for natural stonewalls. But it's worth to try...
                                            Splittest 2 - unexpected
