    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 61.1k Views 40 Watching
    • K Offline
      kaas
      Hi Dale,
      I updated to the new version of ProfileBuilder and now I get these warnings at every startup of SketchUp. PB works fine though.
      I just tested and de-installed PB and the errors are gone. Re-installed PB again and they are back.
      Any idea how to resolve this?
      regards,
      Max
      • K Offline
        kaas
        @Dale, turns out its two of my own plugins that have something to do with this as well although, if I de-install ProfileBuilder the warnings are gone.
        I have two plugins that use:
        require 'win32API'
        require 'FileUtils'
        I was under the impression that using 'require' would prevent these kind of issues. Am I mistaken here?
        You are using the same in PB?
          rv1974
          Whaat, thank you for help\clarifications. At least I'm glad I use the plugin effectively and hope for PB improvements in future. I this particular case if I'm not mistaken the current BP doesn't let me 'infill only' and 'infill special every approx n cm' components.
          And of course even not being 100% polished PB saves me tons of time for sure!
          • W Offline
            Whaat
            require 'win32API'
            require 'FileUtils'
            That is very strange because I do not 'require' those libraries for PB2.
            Perhaps when you have PB2 installed, it changes the timing or sequence of your plugins being loaded which results in the error being displayed. I am guessing one of your plugins has set the following:
            Sketchup.debug_mode = true
            Try searching your plugins for this expression. If you find it, change it to 'false' and see if that solves your problem.
            • K Offline
              kaas
              Very strange indeed.
              I did find the 'debug_mode=' in 1 of my plugins and changed it to false. Also unloaded tt_solidinspector2 that was reported using that argument.
              Still the same errors appear. I might do a fresh re-install of all the plugins in the near future.
              thanks for looking into this.
              • jujuJ Offline
                juju
                Has there been an update to PB2.1? I see it is to the top of the list when i go to EW and organize plugins by "most recent", however it doesn't show in My Extensions as needing to be updated?
                • W Offline
                  Whaat
                  Hi juju,
                  If you have 2.1 already, there is no need to update at this time. The EW probably shows it as most recent because I made a change to the EW page.
                    rv1974
                    Hm.. Sometimes I can't scale entities created with PB2
                    kkkl.skp
                    • W Offline
                      Whaat
                      PB2 actually disables scaling Profile entities that were created with PB2.
                      Because PB2 is a parametric tool, users are encouraged to use the parametric features of PB2 to change the dimensions of the entity rather than the scale tool. When the scale tool is used, things can get messed up, especially in quantity reports.
                        mwm5053
                        Dale this plugin is great, I've used the original PB for years but the ability to create my own profiles and the assembly builder really made this chain possible.
                        Well with the money
                        Walt
                        2011 iMac
                        SU 2015 Pro, 2017 Make
                        V2 Twilight
                        macOS Sierra 10.12.5
                        • W Offline
                          Whaat
                          Well with the money
                          Walt
                          Wow, thanks Walt! That is so great to hear!
                          Would you be interested in copy / pasting your post into a review at the EW page?
                          http://extensions.sketchup.com/en/content/profile-builder-2
                          Cheers,
                          Dale
                            mwm5053
                            Done for sure
                            2011 iMac
                            V2 Twilight
                            • W Offline
                              Whaat
                              @mwm5053 said:
                              Done for sure
                              Thanks so much!
                                rv1974
                                Whaat is it possible to add 'triangulate all' existing profiles? or at least 'triangulate on creation' option? Zillions of unique materials is a HUGEheadache when exporting to Max.
                                P.S. Please check possibility of
                                1. multiple unconnected curves as single path
                                2. faster path (ideally context ignoring single click )finding. Now it's too much clicking.
                                • W Offline
                                  Whaat
                                  SketchUV has a triangulate feature (using right-click context menu) that should do the trick.
                                  SketchUp Extension Warehouse
                                  Your library of custom third-party extensions created to optimize your SketchUp workflow.
                                  (extensions.sketchup.com)
                                    rv1974
                                    Of course. But if you have hundreds profiles nested here and there its hard to find each of them, enter it individually, select face, and only then triangulate.
                                    Thats why some kind of 'triangulate on creation' is so welcomed.
                                      bsfranza
                                      hey there,
                                      how can one change the behaviour of a profile to be extruded smooth or not?
                                      thanks for a hint here 😄
                                      • W Offline
                                        Whaat
                                        @bsfranza said:
                                        hey there,
                                        Sorry, this is not possible. Of course you can use the SketchUp soften edges tool to adjust the smoothness after doing the extrusion.
                                        Can you describe what your use-case is for this feature?
                                        • FrederikF Offline
                                          Frederik
                                          I'm a licensed user of Profile Builder 2...
                                          Extension Manager inform that there's an update available, however, when I click the update button, I get the following message:
                                          "Failed to update Profile Builder 2. Unable to read extension archive."
                                          What's going on...?!?
                                          I can't see that I can update this extension in any other way, but why can't I update this plugin...?!?
                                          BTW... Perhaps worth mentioning that I don't have this issue with any other plugin/extension...
                                          Cheers
                                          Kim Frederik
                                          • sfto1S Offline
                                            sfto1
                                            I have a similar problem with SketchUV
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 10 / 11
