    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 62.3k Views 40 Watching
      rv1974
      Hm.. Sometimes I can't scale entities created with PB2
      kkkl.skp
      • W Offline
        Whaat
        PB2 actually disables scaling Profile entities that were created with PB2.
        Because PB2 is a parametric tool, users are encouraged to use the parametric features of PB2 to change the dimensions of the entity rather than the scale tool. When the scale tool is used, things can get messed up, especially in quantity reports.
          mwm5053
          Dale this plugin is great, I've used the original PB for years but the ability to create my own profiles and the assembly builder really made this chain possible.
          Well with the money
          Walt
          2011 iMac
          SU 2015 Pro, 2017 Make
          V2 Twilight
          macOS Sierra 10.12.5
          • W Offline
            Whaat
            Well with the money
            Walt
            Wow, thanks Walt! That is so great to hear!
            Would you be interested in copy / pasting your post into a review at the EW page?
            http://extensions.sketchup.com/en/content/profile-builder-2
            Cheers,
            Dale
              mwm5053
              Done for sure
              2011 iMac
              V2 Twilight
              • W Offline
                Whaat
                @mwm5053 said:
                Done for sure
                Thanks so much!
                  rv1974
                  Whaat is it possible to add 'triangulate all' existing profiles? or at least 'triangulate on creation' option? Zillions of unique materials is a HUGEheadache when exporting to Max.
                  P.S. Please check possibility of
                  1. multiple unconnected curves as single path
                  2. faster path (ideally context ignoring single click )finding. Now it's too much clicking.
                  • W Offline
                    Whaat
                    SketchUV has a triangulate feature (using right-click context menu) that should do the trick.
                    SketchUp Extension Warehouse
                    Your library of custom third-party extensions created to optimize your SketchUp workflow.
                    (extensions.sketchup.com)
                      rv1974
                      Of course. But if you have hundreds profiles nested here and there its hard to find each of them, enter it individually, select face, and only then triangulate.
                      Thats why some kind of 'triangulate on creation' is so welcomed.
                        bsfranza
                        hey there,
                        how can one change the behaviour of a profile to be extruded smooth or not?
                        thanks for a hint here 😄
                        • W Offline
                          Whaat
                          @bsfranza said:
                          hey there,
                          Sorry, this is not possible. Of course you can use the SketchUp soften edges tool to adjust the smoothness after doing the extrusion.
                          Can you describe what your use-case is for this feature?
                          • FrederikF Offline
                            Frederik
                            I'm a licensed user of Profile Builder 2...
                            Extension Manager inform that there's an update available, however, when I click the update button, I get the following message:
                            "Failed to update Profile Builder 2. Unable to read extension archive."
                            What's going on...?!?
                            I can't see that I can update this extension in any other way, but why can't I update this plugin...?!?
                            BTW... Perhaps worth mentioning that I don't have this issue with any other plugin/extension...
                            Cheers
                            Kim Frederik
                            • sfto1S Offline
                              sfto1
                              I have a similar problem with SketchUV
                                kaas
                                same with PB and Artisan.. must be bought-plugins-with-multiple-email-accounts-problem again...
                                • jujuJ Offline
                                  juju
                                  A quick fix for this problem is to, from within SketchUp, log out of your SketchUp / Trimble account and log back in.
                                  • FrederikF Offline
                                    Frederik
                                    Already tried that trick - unfortunately without any success... 😕
                                    Even re-started SU and also tried signing out, closing SU, restarting Windows, started SU, signed in to the Extension Manager - no luck... 😞
                                    I don't have any issues updating other extensions like Skatter, Skalp, SUbD, Laubwerk, 3skeng Thea4SU etc... etc...
                                    I'm far from a novice with this, yet I can't get the update for Profile Builder 2 to work... 😞
                                    Cheers
                                    Kim Frederik
                                    • PixeroP Offline
                                      Pixero
                                      @Frederik: Have you tried deleting the session.dat file here?
                                      C:\Users\user\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp
                                      Also log out from your browser if you are logged in there as well.
                                      I think it is embarrasing for the SketchUp Team that they can't get this to work.
                                      The SketchUcation extension manager works soo much better IMHO.
                                      • FrederikF Offline
                                        Frederik
                                        I had not tried that until now...
                                        There wasn't any "session.dat" file...
                                        (Before you ask... Yes, I know it's a hidden folder, but I have enabled viewing hidden files and folders and I know where to look, what to do etc. but the file wasn't there...)
                                        I know you wanted to help me, Jan, which I appreciate, but still no luck... 😞
                                        I fully agree...!
                                        But why is this the only extension I have this issue with...? 😕
                                        I have Profile Bulder 2 (2.1.5)
                                        Can someone confirm that there's a newer version available...?!?
                                        Cheers
                                        Kim Frederik
                                        • jujuJ Offline
                                          juju
                                          I had the same as you Frederik, but the logging out and back in worked for me (phew!).
                                          I don't know what changes were made to PB2 and Artisan with the updates, versions report as follows:
                                          • Artisan: 1.3.0
                                          • PB2: 2.1.7
                                          • FrederikF Offline
                                            Frederik
                                            Cheers, Juju! 👍
                                            I also have Artisan and it updated without the message, so I've got Artisan 1.3.0
                                            But the update of PB2 certainly won't work for me... 😕
                                            Cheers
                                            Kim Frederik
                                            • 11
                                            • 10 / 11
