    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 91.3k Views 40 Watching
    • W
      Whaat
      @otb designworks said:
      Can someone tell me what I am doing wrong here?
      Thoughts? I must say I was quite surprised and frustrated by these results as this plugin is held in very high regard and it sure looks very powerful, but I sure can't use it if this is the kind of geometry it creates. Perhaps I am missing something very simple... Thanks in advance
      Hi otb,
      No, you aren't doing anything wrong. There are some known issues with these types of complex paths that move in all three coordination directions and also have small radius curves. I am planning to fix these issues in the next update.
      • O
        otb designworks
        Great news, thanks!
        Cheers, Chuck
        OTB Designworks is on Youtube
        • deaneauD
          deaneau
          Hi Whaat, is it possible to change the currency?. If possible historical curency, too.
          so i could show in my historical project "The Berlin Wall And Inner German Border" the cost of this over the years. Thanks.
          • W
            Whaat
            Hi Deaneau,
            In 2.1, you can change the currency in the Report Settings dialog (access from the Quantifier). Is this what you mean?
              rv1974
              Whaat, I've got some project with kilometers of the attached railing which get turned in a funky manner. My problem is I have to do a lot of stupid manual work. Here's a brief description:
              To get the desired state (1) I build a rough one with the assembly (2) I managed to create.
              Then I manuallyadd some sub-assembly (3) in a 'pale red' areas, explode assembly (2) in order to delete unneeded studs in the corners and rotate the green element (3) appropriately.
              Important note: Our local safety regulations demand vertical netgaps <= 10cm. So in the final output I manage to respect this standard.
              The question is Could my manual labor get solved in my assemly?
              Untitled.skp
              • W
                Whaat
                Hi rv1974,
                These types of assemblies are currently quite tough to do in PB2 as a one step assembly. You are on the right track to break this up into multiple assemblies. It becomes a multi-step process but it is still much faster than doing the whole thing manually. I made a slight change with your corner posts which should save you a bit of time. If you split your corner posts and use a junctions setback, I think you can still get the effect you want at the corners without having to rotate element 4.
                Modified-Railing-Assembly.skp
                • W
                  Whaat
                  @kaas said:
                  Hi Dale,
                  I updated to the new version of ProfileBuilder and now I get these warnings at every startup of SketchUp. PB works fine though.
                  I just tested and de-installed PB and the errors are gone. Re-installed PB again and they are back.
                  Any idea how to resolve this?
                  regards,
                  Max
                  Hi Max,
                  Thanks for reporting this strange issue. I'll look into this and try to get it sorted out. You are the first one to report this so I wonder if there is a conflict with another plugin that you have.
                  Can you please post the full text of the error and not just a screenshot? Thanks!
                  • K
                    kaas
                    @whaat said:
                    Hi Max,
                    Strange coincidence. Will investigate by cleaning the plugin folder and adding one by one.
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:93: warning: already initialized constant FileUtils::OPT_TABLE
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:93: warning: previous definition of OPT_TABLE was here
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1271: warning: already initialized constant FileUtils::Entry_::S_IF_DOOR
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1271: warning: previous definition of S_IF_DOOR was here
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1532: warning: already initialized constant FileUtils::Entry_::DIRECTORY_TERM
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1532: warning: previous definition of DIRECTORY_TERM was here
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1536: warning: already initialized constant FileUtils::Entry_::SYSCASE
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1536: warning: previous definition of SYSCASE was here
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1655: warning: already initialized constant FileUtils::LOW_METHODS
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1655: warning: previous definition of LOW_METHODS was here
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/FileUtils.rb:1661: warning: already initialized constant FileUtils::METHODS
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/fileutils.rb:1661: warning: previous definition of METHODS was here
                    DL is deprecated, please use Fiddle
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/Win32API.rb:8: warning: already initialized constant Win32API::DLL
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/win32API.rb:8: warning: previous definition of DLL was here
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/Win32API.rb:9: warning: already initialized constant Win32API::TYPEMAP
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/win32API.rb:9: warning: previous definition of TYPEMAP was here
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/Win32API.rb:10: warning: already initialized constant Win32API::POINTER_TYPE
                    C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/win32API.rb:10: warning: previous definition of POINTER_TYPE was here
                    • K
                      kaas
                      Hi Dale,
                      regards,
                      Max
                      • K
                        kaas
                        @Dale, turns out its two of my own plugins that have something to do with this as well although, if I de-install ProfileBuilder the warnings are gone.
                        I have two plugins that use:
                        require 'win32API'
                        require 'FileUtils'
                        I was under the impression that using 'require' would prevent these kind of issues. Am I mistaken here?
                        You are using the same in PB?
                          rv1974
                          Whaat, thank you for help\clarifications. At least I'm glad I use the plugin effectively and hope for PB improvements in future. I this particular case if I'm not mistaken the current BP doesn't let me 'infill only' and 'infill special every approx n cm' components.
                          And of course even not being 100% polished PB saves me tons of time for sure!
                          • W
                            Whaat
                            require 'win32API'
                            require 'FileUtils'
                            That is very strange because I do not 'require' those libraries for PB2.
                            Perhaps when you have PB2 installed, it changes the timing or sequence of your plugins being loaded which results in the error being displayed. I am guessing one of your plugins has set the following:
                            Sketchup.debug_mode = true
                            Try searching your plugins for this expression. If you find it, change it to 'false' and see if that solves your problem.
                            • K
                              kaas
                              Very strange indeed.
                              I did find the 'debug_mode=' in 1 of my plugins and changed it to false. Also unloaded tt_solidinspector2 that was reported using that argument.
                              Still the same errors appear. I might do a fresh re-install of all the plugins in the near future.
                              thanks for looking into this.
                              • jujuJ
                                juju
                                Has there been an update to PB2.1? I see it is to the top of the list when i go to EW and organize plugins by "most recent", however it doesn't show in My Extensions as needing to be updated?
                                • W
                                  Whaat
                                  Hi juju,
                                  If you have 2.1 already, there is no need to update at this time. The EW probably shows it as most recent because I made a change to the EW page.
                                    rv1974
                                    Hm.. Sometimes I can't scale entities created with PB2
                                    kkkl.skp
                                    • W
                                      Whaat
                                      PB2 actually disables scaling Profile entities that were created with PB2.
                                      Because PB2 is a parametric tool, users are encouraged to use the parametric features of PB2 to change the dimensions of the entity rather than the scale tool. When the scale tool is used, things can get messed up, especially in quantity reports.
                                        mwm5053
                                        Dale this plugin is great, I've used the original PB for years but the ability to create my own profiles and the assembly builder really made this chain possible.
                                        Well with the money
                                        Walt
                                        2011 iMac
                                        SU 2015 Pro, 2017 Make
                                        V2 Twilight
                                        macOS Sierra 10.12.5
                                        • W
                                          Whaat
                                          Well with the money
                                          Walt
                                          Wow, thanks Walt! That is so great to hear!
                                          Would you be interested in copy / pasting your post into a review at the EW page?
                                          http://extensions.sketchup.com/en/content/profile-builder-2
                                          Cheers,
                                          Dale
                                            mwm5053
                                            Done for sure
                                            2011 iMac
                                            V2 Twilight
                                            • 11
                                            • 10 / 11
