    Hologram
    29 Posts 3 Posters 2.4k Views 3 Watching
    • robertWanR Offline
      robertWan
      Hi.
      Here is described a method of creating holograms with a plugin.
      https://github.com/rdeits/ScratchHolograms/blob/master/Readme.markdown
      But I don't know where in pattern.rb a path to draw_pattern.py can be changed.
      I tired to change it in line 227 and 228 but an error appears.
      Error Loading File solid_pattern.rb
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;228; syntax error, unexpected $undefined, expecting tSTRING_CONTENT or tSTRING_DBEG or tSTRING_DVAR or tSTRING_END
      	Dir.chdir(C;\Documents and Settings\Adminis...
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;228; syntax error, unexpected $undefined, expecting kEND
      ...dir(C;\Documents and Settings\Administrator\My Documents\Scr...
      ...ments\ScratchHolograms-master\ScratchHolograms-master)
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;228; syntax error, unexpected ')', expecting kEND
      Robert
      solid_pattern.rb
        driven
        line 4
        SCRIPTS_DIR = File.dirname(__FILE__)
        PYTHON_PATH = "/usr/local/bin/python"
        "/usr/local/bin/python" need to be your path to where you instal the draw_pattern.py
        I would also changed line 3, then you can leave it all outside of SU and use load "<your path goes here>" from 'Ruby Console' to test it...
        good luck
        john
          robertWan
          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;3; Invalid escape character syntax
          ... and Settings\Administrator\My Documents\ScratchHolograms-ma...
          https://dl.dropboxusercontent.com/s/4tnvdjq10um4f1e/Clipboard01.gif?dl=0
          Robert
          solid_pattern.rb
            robertWan
            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tIDENTIFIER, expecting ')'
            	puts "Data export done. Python res...
            solid_pattern.rb
              driven
              the line 3 error is pointing at you back slash ** try using forward slashes /, ruby uses either but python or system might not...
              and line 230 is missing a closing bracket )...
              sorry
              john
                driven
                it was written for a mac, so maybe...
                	d = IO.popen(PYTHON_PATH + " draw_pattern.py " + base_dir + "/" + proposal)
                possibly needs to be
                	d = IO.popen(File.join(PYTHON_PATH , " draw_pattern.py ",base_dir, proposal))
                john
                EDIT added the missing bracket...
                  The error message points to line #3...
                  Which reads:
                  SCRIPTS_DIR = "C:\Documents and Settings\Administrator\My Documents\ScratchHolograms-master" PYTHON_PATH = "C:\Python27" ...
                  You must always escape the \ folder de-liminator within ANY "" - OR use '' or / etc.
                  So change these everywhere to be something like one of these examples...
                  SCRIPTS_DIR = "C:\\Documents and Settings\\Administrator\\My Documents\\ScratchHolograms-master" ...
                  or
                  SCRIPTS_DIR = 'C:\Documents and Settings\Administrator\My Documents\ScratchHolograms-master' ...
                  or
                  SCRIPTS_DIR = "C:/Documents and Settings/Administrator/My Documents/ScratchHolograms-master" ...
                  or
                  SCRIPTS_DIR = 'C:/Documents and Settings/Administrator/My Documents/ScratchHolograms-master' ...
                  The ' /' is the safer folder-path de-liminator...
                  The \ within "" is taken as an escape character, like in \n == Newline and \t == Tab...
                  [mod=:3v04zt7t]EDIT: @driven just beat me to it, but as I typed it... here it is anyway !
                  πŸ˜’[/mod:3v04zt7t]
                    robertWan
                    Finished exporting vertex data.
                    Running python script...
                    Error; #<Errno;;EACCES; Permission denied - C;/Python27/ draw_pattern.py /C;\Documents and Settings\Administrator\My Documents/Untitled.pattern>
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239
                    http://www.screencast.com/t/2BSBkccw28NW
                    Robert
                    solid_pattern.rb
                      driven
                      Error: #<Errno::EACCES: Permission denied - C:/Python27/ draw_pattern.py /C:\Documents
                      you have spaces before and after draw_pattern.py which may be the issue...
                        robertWan
                        Error; #<Errno;;ENOEXEC; Exec format error - C;/Python27/draw_pattern.py C;\Documents and Settings\Administrator\My Documents/Untitled.pattern>
                        solid_pattern.rb
                          EDIT:
                          I now realize it's about the Windows need for trapping spaces in file paths - change it thus:
                          Change your paths to keep the \ - the system-calls expect them NOT /:
                          SCRIPTS_DIR = "C:\\Documents and Settings\\Administrator\\My Documents\\ScratchHolograms-master" PYTHON_PATH = "C:\\Python27"
                          Then enclose the two parts of the system-call inside "" :
                          IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py"+'" "'+base_dir+"\\"+proposal+'"')
                            robertWan
                            Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
                            current plugin
                              driven
                              have a look at Dan's
                              [Plugin] Hypocycloid Cam Profile Generator v1.0.0 http://sketchucation.com/forums/viewtopic.php?p=470834#p470834
                              it was based on a python [py/dxf] script that I couldn't get to run...
                              he reworked it to SU ruby, may be a simpler approach...
                              john
                                I'm no expert on 'python' but isn't the cmd code more like this:
                                path_to_py argument(s)
                                Also have you got 'python' set up right in cmd window ?
                                ftype Python26.File="C:\Python26\python.exe" "%1" %
                                assoc .py=Python26.File*
                                AND then run it...
                                IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                                OR
                                **system**('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                                OR perhaps the .py part can't be inside "" ?
                                Read this about file associations... http://eli.thegreenplace.net/2010/12/14/problem-passing-arguments-to-python-scripts-on-windows/
                                  robertWan
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $undefined, expecting ')'
                                  ...w_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; unterminated string meets end of file
                                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $end, expecting kEND
                                  solid_pattern.rb
                                    My typo !
                                    2 missing characters...
                                    Try:
                                    IO.popen('"'+PYTHON_PATH+"\\%(#0000FF)["+]draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                                    If you view your code in Notepad++ with suitable RB syntax coloring it's clearly wrong...
                                      robertWan
                                      I use PSPad. I install Notepad++.
                                      Error; #<NameError; undefined local variable or method `draw_pattern' for main;Object>
                                      solid_pattern.rb
                                        Try this:
                                        d = IO.popen('"'+PYTHON_PATH%(#0000BF)[+"\\draw_pattern.py "+]base_dir+"\\"+proposal+'"')
                                        I misunderstood, there is no 'draw_pattern' variable !
                                          robertWan
                                          Error; #<Errno;;EINVAL; Invalid argument - "C;\Python27\draw_pattern.py C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
                                          solid_pattern.rb
                                            I weary... try...
                                            d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+'"\\"+proposal+'"')
                                            So many permutations... πŸ˜’
                                            • 1 / 2
