    Hologram
    29 Posts 3 Posters 2.2k Views 3 Watching
      driven
      line 4
      SCRIPTS_DIR = File.dirname(__FILE__)
      PYTHON_PATH = "/usr/local/bin/python"
      "/usr/local/bin/python" need to be your path to where you instal the draw_pattern.py
      I would also changed line 3, then you can leave it all outside of SU and use load "<your path goes here>" from 'Ruby Console' to test it...
      good luck
      • robertWanR Offline
        robertWan
        Error Loading File solid_pattern.rb
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;3; Invalid escape character syntax
        ... and Settings\Administrator\My Documents\ScratchHolograms-ma...
        https://dl.dropboxusercontent.com/s/4tnvdjq10um4f1e/Clipboard01.gif?dl=0
        Robert
        solid_pattern.rb
          robertWan
          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tIDENTIFIER, expecting ')'
          	puts "Data export done. Python res...
          solid_pattern.rb
            driven
            the line 3 error is pointing at you back slash ** try using forward slashes /, ruby uses either but python or system might not...
            and line 230 is missing a closing bracket )...
            sorry
              driven
              it was written for a mac, so maybe...
              	d = IO.popen(PYTHON_PATH + " draw_pattern.py " + base_dir + "/" + proposal)
              possibly needs to be
              	d = IO.popen(File.join(PYTHON_PATH , " draw_pattern.py ",base_dir, proposal))
              EDIT added the missing bracket...
                The error message points to line #3...
                Which reads:
                SCRIPTS_DIR = "C:\Documents and Settings\Administrator\My Documents\ScratchHolograms-master" PYTHON_PATH = "C:\Python27" ...
                You must always escape the \ folder de-liminator within ANY "" - OR use '' or / etc.
                So change these everywhere to be something like one of these examples...
                SCRIPTS_DIR = "C:\\Documents and Settings\\Administrator\\My Documents\\ScratchHolograms-master" ...
                or
                SCRIPTS_DIR = 'C:\Documents and Settings\Administrator\My Documents\ScratchHolograms-master' ...
                or
                SCRIPTS_DIR = "C:/Documents and Settings/Administrator/My Documents/ScratchHolograms-master" ...
                or
                SCRIPTS_DIR = 'C:/Documents and Settings/Administrator/My Documents/ScratchHolograms-master' ...
                The ' /' is the safer folder-path de-liminator...
                The \ within "" is taken as an escape character, like in \n == Newline and \t == Tab...
                [mod=:3v04zt7t]EDIT: @driven just beat me to it, but as I typed it... here it is anyway !
                πŸ˜’[/mod:3v04zt7t]
                  robertWan
                  Finished exporting vertex data.
                  Running python script...
                  Error; #<Errno;;EACCES; Permission denied - C;/Python27/ draw_pattern.py /C;\Documents and Settings\Administrator\My Documents/Untitled.pattern>
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239
                  http://www.screencast.com/t/2BSBkccw28NW
                  Robert
                  solid_pattern.rb
                    driven
                    Error: #<Errno::EACCES: Permission denied - C:/Python27/ draw_pattern.py /C:\Documents
                    you have spaces before and after draw_pattern.py which may be the issue...
                      robertWan
                      Error; #<Errno;;ENOEXEC; Exec format error - C;/Python27/draw_pattern.py C;\Documents and Settings\Administrator\My Documents/Untitled.pattern>
                      solid_pattern.rb
                        EDIT:
                        I now realize it's about the Windows need for trapping spaces in file paths - change it thus:
                        Change your paths to keep the \ - the system-calls expect them NOT /:
                        SCRIPTS_DIR = "C:\\Documents and Settings\\Administrator\\My Documents\\ScratchHolograms-master" PYTHON_PATH = "C:\\Python27"
                        Then enclose the two parts of the system-call inside "" :
                        IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py"+'" "'+base_dir+"\\"+proposal+'"')
                          robertWan
                          Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
                          current plugin
                            driven
                            have a look at Dan's
                            [Plugin] Hypocycloid Cam Profile Generator v1.0.0 http://sketchucation.com/forums/viewtopic.php?p=470834#p470834
                            it was based on a python [py/dxf] script that I couldn't get to run...
                            he reworked it to SU ruby, may be a simpler approach...
                              I'm no expert on 'python' but isn't the cmd code more like this:
                              path_to_py argument(s)
                              Also have you got 'python' set up right in cmd window ?
                              ftype Python26.File="C:\Python26\python.exe" "%1" %
                              assoc .py=Python26.File*
                              AND then run it...
                              IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                              OR
                              **system**('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                              OR perhaps the .py part can't be inside "" ?
                              Read this about file associations... http://eli.thegreenplace.net/2010/12/14/problem-passing-arguments-to-python-scripts-on-windows/
                                robertWan
                                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $undefined, expecting ')'
                                ...w_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; unterminated string meets end of file
                                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $end, expecting kEND
                                solid_pattern.rb
                                  My typo !
                                  2 missing characters...
                                  Try:
                                  IO.popen('"'+PYTHON_PATH+"\\%(#0000FF)["+]draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                                  If you view your code in Notepad++ with suitable RB syntax coloring it's clearly wrong...
                                    robertWan
                                    I use PSPad. I install Notepad++.
                                    Error; #<NameError; undefined local variable or method `draw_pattern' for main;Object>
                                    solid_pattern.rb
                                      Try this:
                                      d = IO.popen('"'+PYTHON_PATH%(#0000BF)[+"\\draw_pattern.py "+]base_dir+"\\"+proposal+'"')
                                      I misunderstood, there is no 'draw_pattern' variable !
                                        robertWan
                                        Error; #<Errno;;EINVAL; Invalid argument - "C;\Python27\draw_pattern.py C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
                                        solid_pattern.rb
                                          I weary... try...
                                          d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+'"\\"+proposal+'"')
                                          So many permutations... πŸ˜’
                                            robertWan
                                            @tig said:
                                            I weary
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tCONSTANT, expecting ')'
                                            	puts "Data export done. Python results w...
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;237; syntax error, unexpected tIDENTIFIER, expecting kEND
                                            if(file_loaded("solid_pattern.rb"))
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;238; syntax error, unexpected tCONSTANT, expecting kEND
                                            	 menu = UI.menu("Plugins");
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239; syntax error, unexpected tCONSTANT, expecting kEND
                                            	menu.add_item("Make Solid Scratch Pattern...") { ExportPattern() }
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected tIDENTIFIER, expecting kEND
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; unterminated string meets end of file
                                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected $end, expecting kEND
                                            solid_pattern.rb
