    Hologram
    29 Posts 3 Posters 2.1k Views 3 Watching
    • robertWanR Offline
      robertWan
      @tig said:
      I weary
      Error Loading File solid_pattern.rb
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tCONSTANT, expecting ')'
      	puts "Data export done. Python results w...
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;237; syntax error, unexpected tIDENTIFIER, expecting kEND
      if(file_loaded("solid_pattern.rb"))
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;238; syntax error, unexpected tCONSTANT, expecting kEND
      	 menu = UI.menu("Plugins");
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239; syntax error, unexpected tCONSTANT, expecting kEND
      	menu.add_item("Make Solid Scratch Pattern...") { ExportPattern() }
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected tIDENTIFIER, expecting kEND
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; unterminated string meets end of file
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected $end, expecting kEND
      solid_pattern.rb
        I must sleep now...
        BUT I think this is it...
        d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+proposal+'"')
          robertWan
          Nothing worked out, did it?
          Finished exporting vertex data.
          Running python script...
          Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My DocumentsUntitled.pattern">
          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
          C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
          solid_pattern.rb
            I assume the .py and .pattern files exist ?
            Try this instead - there was a missing \ before ' proposal':
            d = system('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir%(#0000FF)[+"\\"]+proposal+'"')
            If you paste this into a Windows cmd window [including the "s] does it work ?
            "C:\Python27\draw_pattern.py" "C:\Documents and Settings\Administrator\My Documents%(#0000FF)[\]**Untitled**.pattern" - substitute the **Untitled** with another name if appropriate...
              robertWan
              Data export done. Python results will appear as soon as they are completed
              Error; #<NoMethodError; private method `gets' called for false;FalseClass>
              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;231;in `ExportPattern'
              http://www.screencast.com/t/lDjsrKcXTb
                So it's working, sort of... πŸ˜•
                d is set to the result of the system call...
                Then if fails at:
                while d.gets != nil puts d.gets end
                Because ' d' is ' false' !
                Why no add a puts d just after the system call to see what you are getting...
                I suspect it'll NOT be complex data - just success/failure true/false ??
                Also in the screen-cast the .py extension was not recognized as being associated with Python !
                Go back a few posts to see my advice and the links etc, on ensuring this is set up correctly...
                Also in the screen-cast the file was named Untitled.pattern**abc** ?
                Why the extra characters ?
                When you run the .py what do you expect ?
                If it's 'data' then I suggest you get the .py to write it into to a [temporary] file then use IO.read on it in Ruby to get that data...
                You might need to add a sleep and test for the existence of that file before using IO, as once you launch the Python process it will run separately from the Ruby side...
                  driven
                  @tig
                  on mac if you drag a file to the 'cmd promt ' [i.e. Terminal.app], you get the correctly escaped full path...
                  you can then either harcode that path for a test or change the system call to puts to see if they match...
                  does that work on a PC?
                  john
                    robertWan
                    Also in the screen-cast the file was named Untitled.patternabc ?
                    I wrote it in SU in that plugin window. I know, it makes no sense, I've changed the extension. But when I kept the same name and extension the result was the same.
                    Robert
                      So is it an error in your .file ?
                      • 2 / 2
