    Hologram
    29 Posts 3 Posters 3.2k Views 3 Watching
      driven
      Error: #<Errno::EACCES: Permission denied - C:/Python27/ draw_pattern.py /C:\Documents
      you have spaces before and after draw_pattern.py which may be the issue...
      • robertWanR
        robertWan
        Finished exporting vertex data.
        Running python script...
        Error; #<Errno;;ENOEXEC; Exec format error - C;/Python27/draw_pattern.py C;\Documents and Settings\Administrator\My Documents/Untitled.pattern>
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
        C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239
        solid_pattern.rb
          EDIT:
          I now realize it's about the Windows need for trapping spaces in file paths - change it thus:
          Change your paths to keep the \ - the system-calls expect them NOT /:
          SCRIPTS_DIR = "C:\\Documents and Settings\\Administrator\\My Documents\\ScratchHolograms-master" PYTHON_PATH = "C:\\Python27"
          Then enclose the two parts of the system-call inside "" :
          IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py"+'" "'+base_dir+"\\"+proposal+'"')
          • robertWanR
            robertWan
            Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
            current plugin
              driven
              have a look at Dan's
              [Plugin] Hypocycloid Cam Profile Generator v1.0.0 http://sketchucation.com/forums/viewtopic.php?p=470834#p470834
              it was based on a python [py/dxf] script that I couldn't get to run...
              he reworked it to SU ruby, may be a simpler approach...
                I'm no expert on 'python' but isn't the cmd code more like this:
                path_to_py argument(s)
                Also have you got 'python' set up right in cmd window ?
                ftype Python26.File="C:\Python26\python.exe" "%1" %
                assoc .py=Python26.File*
                AND then run it...
                IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                OR
                **system**('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                OR perhaps the .py part can't be inside "" ?
                Read this about file associations... http://eli.thegreenplace.net/2010/12/14/problem-passing-arguments-to-python-scripts-on-windows/
                • robertWanR
                  robertWan
                  Error Loading File solid_pattern.rb
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $undefined, expecting ')'
                  ...w_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; unterminated string meets end of file
                  C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $end, expecting kEND
                  solid_pattern.rb
                    My typo !
                    2 missing characters...
                    Try:
                    IO.popen('"'+PYTHON_PATH+"\\%(#0000FF)["+]draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                    If you view your code in Notepad++ with suitable RB syntax coloring it's clearly wrong...
                    • robertWanR
                      robertWan
                      I use PSPad. I install Notepad++.
                      Error; #<NameError; undefined local variable or method `draw_pattern' for main;Object>
                      solid_pattern.rb
                        Try this:
                        d = IO.popen('"'+PYTHON_PATH%(#0000BF)[+"\\draw_pattern.py "+]base_dir+"\\"+proposal+'"')
                        I misunderstood, there is no 'draw_pattern' variable !
                        • robertWanR
                          robertWan
                          Error; #<Errno;;EINVAL; Invalid argument - "C;\Python27\draw_pattern.py C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
                          solid_pattern.rb
                            I weary... try...
                            d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+'"\\"+proposal+'"')
                            So many permutations... πŸ˜’
                            • robertWanR
                              robertWan
                              @tig said:
                              I weary
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tCONSTANT, expecting ')'
                              	puts "Data export done. Python results w...
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;237; syntax error, unexpected tIDENTIFIER, expecting kEND
                              if(file_loaded("solid_pattern.rb"))
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;238; syntax error, unexpected tCONSTANT, expecting kEND
                              	 menu = UI.menu("Plugins");
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239; syntax error, unexpected tCONSTANT, expecting kEND
                              	menu.add_item("Make Solid Scratch Pattern...") { ExportPattern() }
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected tIDENTIFIER, expecting kEND
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; unterminated string meets end of file
                              C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected $end, expecting kEND
                              solid_pattern.rb
                                I must sleep now...
                                BUT I think this is it...
                                d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+proposal+'"')
                                • robertWanR
                                  robertWan
                                  Nothing worked out, did it?
                                  Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My DocumentsUntitled.pattern">
                                  solid_pattern.rb
                                    I assume the .py and .pattern files exist ?
                                    Try this instead - there was a missing \ before ' proposal':
                                    d = system('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir%(#0000FF)[+"\\"]+proposal+'"')
                                    If you paste this into a Windows cmd window [including the "s] does it work ?
                                    "C:\Python27\draw_pattern.py" "C:\Documents and Settings\Administrator\My Documents%(#0000FF)[\]**Untitled**.pattern" - substitute the **Untitled** with another name if appropriate...
                                    • robertWanR
                                      robertWan
                                      Data export done. Python results will appear as soon as they are completed
                                      Error; #<NoMethodError; private method `gets' called for false;FalseClass>
                                      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;231;in `ExportPattern'
                                      (www.screencast.com)
                                        So it's working, sort of... πŸ˜•
                                        d is set to the result of the system call...
                                        Then if fails at:
                                        while d.gets != nil puts d.gets end
                                        Because ' d' is ' false' !
                                        Why no add a puts d just after the system call to see what you are getting...
                                        I suspect it'll NOT be complex data - just success/failure true/false ??
                                        Also in the screen-cast the .py extension was not recognized as being associated with Python !
                                        Go back a few posts to see my advice and the links etc, on ensuring this is set up correctly...
                                        Also in the screen-cast the file was named Untitled.pattern**abc** ?
                                        Why the extra characters ?
                                        When you run the .py what do you expect ?
                                        If it's 'data' then I suggest you get the .py to write it into to a [temporary] file then use IO.read on it in Ruby to get that data...
                                        You might need to add a sleep and test for the existence of that file before using IO, as once you launch the Python process it will run separately from the Ruby side...
                                          driven
                                          @tig
                                          on mac if you drag a file to the 'cmd promt ' [i.e. Terminal.app], you get the correctly escaped full path...
                                          you can then either harcode that path for a test or change the system call to puts to see if they match...
                                          does that work on a PC?
                                          • robertWanR
                                            robertWan
                                            Also in the screen-cast the file was named Untitled.patternabc ?
                                            I wrote it in SU in that plugin window. I know, it makes no sense, I've changed the extension. But when I kept the same name and extension the result was the same.
                                            Robert
