    Hologram
    29 Posts 3 Posters 3.2k Views 3 Watching
    • robertWanR
      robertWan
      Finished exporting vertex data.
      Running python script...
      Error; #<Errno;;ENOEXEC; Exec format error - C;/Python27/draw_pattern.py C;\Documents and Settings\Administrator\My Documents/Untitled.pattern>
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `popen'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229;in `ExportPattern'
      C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239
      solid_pattern.rb
        EDIT:
        I now realize it's about the Windows need for trapping spaces in file paths - change it thus:
        Change your paths to keep the \ - the system-calls expect them NOT /:
        SCRIPTS_DIR = "C:\\Documents and Settings\\Administrator\\My Documents\\ScratchHolograms-master" PYTHON_PATH = "C:\\Python27"
        Then enclose the two parts of the system-call inside "" :
        IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py"+'" "'+base_dir+"\\"+proposal+'"')
        • robertWanR
          robertWan
          Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
          current plugin
            driven
            have a look at Dan's
            [Plugin] Hypocycloid Cam Profile Generator v1.0.0 http://sketchucation.com/forums/viewtopic.php?p=470834#p470834
            it was based on a python [py/dxf] script that I couldn't get to run...
            he reworked it to SU ruby, may be a simpler approach...
              I'm no expert on 'python' but isn't the cmd code more like this:
              path_to_py argument(s)
              Also have you got 'python' set up right in cmd window ?
              ftype Python26.File="C:\Python26\python.exe" "%1" %
              assoc .py=Python26.File*
              AND then run it...
              IO.popen('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
              OR
              **system**('"'+PYTHON_PATH+"\\draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
              OR perhaps the .py part can't be inside "" ?
              Read this about file associations... http://eli.thegreenplace.net/2010/12/14/problem-passing-arguments-to-python-scripts-on-windows/
              • robertWanR
                robertWan
                Error Loading File solid_pattern.rb
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $undefined, expecting ')'
                ...w_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; unterminated string meets end of file
                C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;229; syntax error, unexpected $end, expecting kEND
                solid_pattern.rb
                  My typo !
                  2 missing characters...
                  Try:
                  IO.popen('"'+PYTHON_PATH+"\\%(#0000FF)["+]draw_pattern.py+'" "'+base_dir+"\\"+proposal+'"')
                  If you view your code in Notepad++ with suitable RB syntax coloring it's clearly wrong...
                  • robertWanR
                    robertWan
                    I use PSPad. I install Notepad++.
                    Error; #<NameError; undefined local variable or method `draw_pattern' for main;Object>
                    solid_pattern.rb
                      Try this:
                      d = IO.popen('"'+PYTHON_PATH%(#0000BF)[+"\\draw_pattern.py "+]base_dir+"\\"+proposal+'"')
                      I misunderstood, there is no 'draw_pattern' variable !
                      • robertWanR
                        robertWan
                        Error; #<Errno;;EINVAL; Invalid argument - "C;\Python27\draw_pattern.py C;\Documents and Settings\Administrator\My Documents\Untitled.pattern">
                        solid_pattern.rb
                          I weary... try...
                          d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+'"\\"+proposal+'"')
                          So many permutations... πŸ˜’
                          • robertWanR
                            robertWan
                            @tig said:
                            I weary
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;230; syntax error, unexpected tCONSTANT, expecting ')'
                            	puts "Data export done. Python results w...
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;237; syntax error, unexpected tIDENTIFIER, expecting kEND
                            if(file_loaded("solid_pattern.rb"))
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;238; syntax error, unexpected tCONSTANT, expecting kEND
                            	 menu = UI.menu("Plugins");
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;239; syntax error, unexpected tCONSTANT, expecting kEND
                            	menu.add_item("Make Solid Scratch Pattern...") { ExportPattern() }
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected tIDENTIFIER, expecting kEND
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; unterminated string meets end of file
                            C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;243; syntax error, unexpected $end, expecting kEND
                            solid_pattern.rb
                              I must sleep now...
                              BUT I think this is it...
                              d = IO.popen('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir+proposal+'"')
                              • robertWanR
                                robertWan
                                Nothing worked out, did it?
                                Error; #<Errno;;ENOEXEC; Exec format error - "C;\Python27\draw_pattern.py" "C;\Documents and Settings\Administrator\My DocumentsUntitled.pattern">
                                solid_pattern.rb
                                  I assume the .py and .pattern files exist ?
                                  Try this instead - there was a missing \ before ' proposal':
                                  d = system('"'+PYTHON_PATH+'\draw_pattern.py" "'+base_dir%(#0000FF)[+"\\"]+proposal+'"')
                                  If you paste this into a Windows cmd window [including the "s] does it work ?
                                  "C:\Python27\draw_pattern.py" "C:\Documents and Settings\Administrator\My Documents%(#0000FF)[\]**Untitled**.pattern" - substitute the **Untitled** with another name if appropriate...
                                  • robertWanR
                                    robertWan
                                    Data export done. Python results will appear as soon as they are completed
                                    Error; #<NoMethodError; private method `gets' called for false;FalseClass>
                                    C;/Program Files (x86)/Google/Google SketchUp 8/Plugins/solid_pattern.rb;231;in `ExportPattern'
                                    (www.screencast.com)
                                      So it's working, sort of... πŸ˜•
                                      d is set to the result of the system call...
                                      Then if fails at:
                                      while d.gets != nil puts d.gets end
                                      Because ' d' is ' false' !
                                      Why no add a puts d just after the system call to see what you are getting...
                                      I suspect it'll NOT be complex data - just success/failure true/false ??
                                      Also in the screen-cast the .py extension was not recognized as being associated with Python !
                                      Go back a few posts to see my advice and the links etc, on ensuring this is set up correctly...
                                      Also in the screen-cast the file was named Untitled.pattern**abc** ?
                                      Why the extra characters ?
                                      When you run the .py what do you expect ?
                                      If it's 'data' then I suggest you get the .py to write it into to a [temporary] file then use IO.read on it in Ruby to get that data...
                                      You might need to add a sleep and test for the existence of that file before using IO, as once you launch the Python process it will run separately from the Ruby side...
                                        driven
                                        @tig
                                        on mac if you drag a file to the 'cmd promt ' [i.e. Terminal.app], you get the correctly escaped full path...
                                        you can then either harcode that path for a test or change the system call to puts to see if they match...
                                        does that work on a PC?
                                        • robertWanR
                                          robertWan
                                          Also in the screen-cast the file was named Untitled.patternabc ?
                                          I wrote it in SU in that plugin window. I know, it makes no sense, I've changed the extension. But when I kept the same name and extension the result was the same.
                                          Robert
                                            So is it an error in your .file ?
