    Cycles Render
    30 Posts 8 Posters 6.7k Views 8 Watching
    • david57D Offline
      david57
      Rendered with Cycles.
      Using plants i found at the sketch-up 3dwarehouse, on the
      lower right hand corner.
      • david57D Offline
        david57
        • srxS Offline
          srx
          Looks very good. Could you share links to plants models?
          www.saurus.rs
          • Bryan KB Offline
            Wow, that DOES look very good!
            • david57D Offline
              david57
              Thanks, Trees and bushes are made with ngPlant.
                Cycles in Blender?
                • david57D Offline
                  david57
                  Yes, Cycles in Blender.
                  • david57D Offline
                    david57
                    An unfinished update.
                      You should play with the clamp values to see if that resolves the fireflies in the image.
                      Also under Light Paths tweak some of the bounces and make sure caustics are off.
                      • hellnbakH Offline
                        hellnbak
                        Any chance of seeing some larger photos?
                        • david57D Offline
                          david57
                          Yes, I've been trying out many different settings to get the fireflies out.
                          I don't have a GPU and that's why im rendering low quality images.
                          Here's a smaller one.
                          • novenaN Offline
                            novena
                            david57,
                            nice work! probably you have seen this before, if not, this can help you to get rid of fireflies in cycles...
                            http://www.blenderguru.com/articles/7-ways-get-rid-fireflies/#.VM2KUWjF98E
                            best
                            V
                            http://hdzarkitektur.wordpress.com/
                            • GarethG Offline
                              Gareth
                              ngPlant is excellent.
                              i have been experimenting with it for a few days
                              ....but how do you get the models into SketchUp with the textures showing properly (i am using Obj import but some faces are reversed and when i reverse the back faces the textures are missing)...?
                              • GarethG Offline
                                Gareth
                                Problem solved (mostly).....a lower resolution seems to fix the faces issue, but it isn't giving me the result i really want
                                  Resolution has nothing to do with it.
                                  Did you recalculate the normals in Blender? CTRL + N
                                  Also if you export the .obj without triangulating first then on import into SU you are playing Russian roulette as to what SU will do.
                                    You have also Cycles as Standalone! β˜€
                                    So no need to learn Blender! πŸ’š
                                    Here integration with Moment Of Inspiration!
                                      @pilou
                                      no textures in MoI 😞
                                        Be patient! πŸ˜„ It's now for pure design mechanical pieces! πŸ€“
                                        • GarethG Offline
                                          Gareth
                                          Nope.....I don't use Blender....is that a prerequisite ?
                                            From what I understand SU can use Cycles Standalone if someone makes a little plugin inbetweener πŸ˜‰
                                            • 1 / 2
