    Cycles Render
    30 Posts 8 Posters 7.3k Views 8 Watching
    • david57D Offline
      david57
      Thanks, Trees and bushes are made with ngPlant.
        Cycles in Blender?
        • david57D Offline
          david57
          Yes, Cycles in Blender.
          • david57D Offline
            david57
            An unfinished update.
              You should play with the clamp values to see if that resolves the fireflies in the image.
              Also under Light Paths tweak some of the bounces and make sure caustics are off.
              • hellnbakH Offline
                hellnbak
                Any chance of seeing some larger photos?
                • david57D Offline
                  david57
                  Yes, I've been trying out many different settings to get the fireflies out.
                  I don't have a GPU and that's why im rendering low quality images.
                  Here's a smaller one.
                  • novenaN Offline
                    novena
                    david57,
                    nice work! probably you have seen this before, if not, this can help you to get rid of fireflies in cycles...
                    http://www.blenderguru.com/articles/7-ways-get-rid-fireflies/#.VM2KUWjF98E
                    best
                    V
                    http://hdzarkitektur.wordpress.com/
                    • GarethG Offline
                      Gareth
                      ngPlant is excellent.
                      i have been experimenting with it for a few days
                      ....but how do you get the models into SketchUp with the textures showing properly (i am using Obj import but some faces are reversed and when i reverse the back faces the textures are missing)...?
                      • GarethG Offline
                        Gareth
                        Problem solved (mostly).....a lower resolution seems to fix the faces issue, but it isn't giving me the result i really want
                          Resolution has nothing to do with it.
                          Did you recalculate the normals in Blender? CTRL + N
                          Also if you export the .obj without triangulating first then on import into SU you are playing Russian roulette as to what SU will do.
                            You have also Cycles as Standalone! β˜€
                            So no need to learn Blender! πŸ’š
                            Here integration with Moment Of Inspiration!
                              @pilou
                              no textures in MoI 😞
                                Be patient! πŸ˜„ It's now for pure design mechanical pieces! πŸ€“
                                • GarethG Offline
                                  Gareth
                                  Nope.....I don't use Blender....is that a prerequisite ?
                                    From what I understand SU can use Cycles Standalone if someone makes a little plugin inbetweener πŸ˜‰
                                      Well considering this thread was related to Blender I just presumed you were using blender. Obviously on re-reading it's clearer that it is the ngPlant that you are using.
                                      So in ngPlant is there an option to triangualate the mesh on export? Or preferably to triangulate it on creation.
                                      If ngPlant creates non-planar quads and you export non-planars quads to .obj then SU will spit it's dummy out.
                                      • david57D Offline
                                        david57
                                        novena,
                                        Thanks,I have to read that article on removing those fireflies.
                                        Rich O Brien,
                                        I dont think ngPlant has that option to triangualate the model.
                                        Gareth,
                                        Im using a ruby script called "lwo_export.rb" to export the model as
                                        a light wave model. I use sketch up version 7 for that script.
                                        I dont know if it works on all new versions of sketchup.
                                        • david57D Offline
                                          david57
                                          I found more sketch-up plants to render and test. They are in the front
                                          of this render. Also i made 2 leaves with blender and was curious to see
                                          how the render. They are near the center of the render.
                                          • david57D Offline
                                            david57
