    Export just shadows
    40 Posts 8 Posters 22.5k Views 8 Watching
      suSteve
      I followed some posts on just exporting shadows:
      Shadows only": View>Face style>Monochrome; View>Edge style>Uncheck all; Shadow settings dialog, Light 100, Dark 0, Shadows on; Window>Styles>Face settings, set the default colour for both Front and Back faces to pure white. If you want to show transparency, put all transparent objects on a different layer and turn that off.
      I end up with the following screenshot. Any ideas what I am missing?
      thanks
      • ely862meE Offline
        ely862me
        I believe you have some shadows on the faces too. Try to uncheck the "On faces" option.
        Elisei (sketchupper)
        Come and See EliseiDesign
          suSteve
          thanks for the reply. Unchecking on faces has the same result
          • pbacotP Offline
            Check your light-dark settings. Light 100 and dark 0 (according to your proposed setup)
            • ely862meE Offline
              ely862me
              Can you share your model ?
              I have never tried this either. For the moment, if I choose Hidden lines mode and uncheck all the edges I get this.
                suSteve
                thanks. Model attached (its just a box)
                thanks again
                shadows only.skp
                • ely862meE Offline
                  ely862me
                  Go to Face style and select hidden lines then uncheck all the edges. Also uncheck the sky.
                  shadows only a.skp
                    suSteve
                    thank you for taking the time to look at this and thanks for the answer
                      I've done a tutorial on this here on SCF somewhere. I use shadow only exports frequently to create soft shadows and the appearance of multiple light sources.
                        suSteve
                        still struggling with this one. If I export to png or tiff for a transparent background then I end up with the box again as this is not transparent. Is it possible to export with a transparent background?
                        thanks
                          driven
                          hi
                          export without trans...
                          open in Preview. magic wand the background...
                          john
                            suSteve
                            thanks John,
                            can do but wondered if there was a way of managing it in SU
                            • BoxB Offline
                              With 2015 you can export ,png with transparent background.
                              Like this.
                              http://i155.photobucket.com/albums/s296/storeben/SU/Shadows.png
                                suSteve
                                Do you have a copy of the skp you have used for the .png? I have exported to png (transparency) which is where the object was visible.
                                thanks
                                  driven
                                  I don't know if you can exclude a 3d shape shadows, on a mac...
                                  have a look at tig's Shadow Projectorhttp://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=41885
                                  you can hide everything else than export a png/tiff of just the shape of a shadow...
                                  this is geometry, on the ground...
                                  john
                                  • jeff hammondJ Offline
                                    jeff hammond
                                    some rendering apps can render only shadows with transparent everything else.
                                    the upside is you get very clean shadows which render relatively quick.. the downside is it's maybe overkill for what you're trying to accomplish in the end.
                                    so what, exactly, are you trying to accomplish?
                                    dotdotdot
                                      suSteve
                                      Thanks. I am on a Mac.
                                      I wanted to just export shadows only with a transparent background.
                                        jeff hammond
                                        like that's it? that's the final goal?
                                        my point is that there may be other ways to reach your goal
                                        dotdotdot
                                          driven
                                          Jeff, Dave and I also use mac...
                                          I think tig's plugin or a renderer are the options...
                                          how are you wanting to use the results?
                                          john
                                            suSteve
                                            I am following this http://www.ronenbekerman.com/making-of-urban-plaza/
                                            • 1 / 2
