    Shadows on ground ... but not on objects
    22 Posts 7 Posters 1.7k Views 7 Watching
      djh
      How can one display the shadows on objects as well as on the ground?
      • ely862meE Offline
        ely862me
        If those are groups or components make sure in the entity info they have the "Receive shadows" option checked. Right click on the group/component/Entity info/Check Receive shadows
        Elisei (sketchupper)
        Come and See EliseiDesign
          djh
            djh
            Still doesn't receive shadows.
            • BoxB Offline
              Can you share the skp, it's hard to guess from images.
              • FrederikF Offline
                Frederik
                I can't replicate this...
                What version of SU are you using...??
                Cheers
                Kim Frederik
                • BoxB Offline
                  That's why I asked for the model Kim, I'm guessing it's a style issue or a transparent material.
                  • FrederikF Offline
                    Frederik
                    I just saw it, Box...
                    But look at the time you posted and the time I did... πŸ˜„
                    Cheers
                    Kim Frederik
                      djh
                      I tried to upload the model, but it says that it's too big to upload. How can I share it with you?
                        djh
                        One way to fix the problem is to copy and paste as a new file - the shadows are on the objects too.
                        • ely862meE Offline
                          ely862me
                          You can upload up to 4mb. You can compress the file and it might get smaller. But for such a few geometry I wonder why the file exceeds 4mb ?
                          Most likely as Box said it is about the style you are using, in that case you could go to Window/Styles/Default styles and pick Simple style, and check the shadows back on. It should work.
                          When pasting the geometry in a new file, you get back to the Simple style which is a default style.
                          • BoxB Offline
                            In the shadow settings dialog, have you unticked On Faces?
                              djh
                              [quote="ely862me"]
                              Didn't help.
                                djh
                                Yes, but it didn't help. The only method that helped was to copy and paste to a new file.
                                • jeff hammondJ Offline
                                  jeff hammond
                                  it's possible you've fiddled with the shadow light & dark settings..
                                  dotdotdot
                                    slbaumgartner
                                    Your picture suggests that you have nested groups. Have you enabled receive shadows on all the levels of nesting? A nested object will not receive shadows if its containing group does not.
                                      That's a good observation.
                                      @djh, you might try exploding all your groups and components to see what happens.
                                      You say, though, that copying the model to a new file fixed the problem. That might indicate you have a corrupted file.
                                        djh
                                        [attachment=1:1i2nw2cq]<!-- ia1 -->Screen Shot 2014-11-20 at 11.30.27 AM.png<!-- ia1 -->[/attachment:1i2nw2cq]
                                        [attachment=0:1i2nw2cq]<!-- ia0 -->Screen Shot 2014-11-20 at 11.30.43 AM.png<!-- ia0 -->[/attachment:1i2nw2cq]
                                        I did fiddle with them. Then, I fiddled with them again and again, but it only affected the shadows that were present. It didn't seem to restore the shadows on the objects.
                                          djh
                                          Sorry, I don't know what nesting is. All objects are on Layer0. I exploded all of the objects, but the shadows still don't appear on the objects.
                                            djh
                                            Yes.
                                            • 1 / 2
