    Shadows on ground ... but not on objects
    22 Posts 7 Posters 2.3k Views 7 Watching
    • D
      djh
      @dave r said:
      @slbaumgartner said:
      Your picture suggests that you have nested groups. Have you enabled receive shadows on all the levels of nesting? A nested object will not receive shadows if its containing group does not.
      That's a good observation.
      @djh, you might try exploding all your groups and components to see what happens.
      You say, though, that copying the model to a new file fixed the problem. That might indicate you have a corrupted file.
      It probably is a corrupted file.
      • S
        slbaumgartner
        Sorry, I don't know what nesting is. All objects are on Layer0. I exploded all of the objects, but the shadows still don't appear on the objects.
        As Dave has pointed out, it is possible that the file is corrupted. The following is meant to be tutorial, in reply to your statement that you don't know what nesting is, since if you don't understand that concept it is still possible it is the cause of your issue. For example, if you don't get the idea, "exploded all of the objects" might actually have left something intact.
        "Nesting" is when you place or create a Group or ComponentInstance inside another Group or ComponentInstance. In your "still doesn't receive shadows" jpg, I see two different bounding boxes surrounding the selected Face, one around the corner panels and one around the rectangular group of corners (a room?). Due to the style I am not certain whether the panel on which the Face lies is also a Group. So, there could potentially be a Face nested in a panel Group nested in a corner Group nested in a room Group.
        The importance in this particular case is that the settings on containers and the things they contain interact. Specifically, shadows won't be cast on the Face unless the flag is set correctly on each of those levels of nesting.
        [edited to change "layers" to levels in the last sentence - poor choice of words since "layers" are a different thing]
        • 2 / 2
