    Shadows on ground ... but not on objects
    22 Posts 7 Posters 2.1k Views 7 Watching
    • ely862meE
      ely862me
      If those are groups or components make sure in the entity info they have the "Receive shadows" option checked. Right click on the group/component/Entity info/Check Receive shadows
      Elisei (sketchupper)
      Come and See EliseiDesign
        djh
          djh
          Still doesn't receive shadows.
          • BoxB
            Can you share the skp, it's hard to guess from images.
            • FrederikF
              Frederik
              I can't replicate this...
              What version of SU are you using...??
              Cheers
              Kim Frederik
              • BoxB
                That's why I asked for the model Kim, I'm guessing it's a style issue or a transparent material.
                • FrederikF
                  Frederik
                  I just saw it, Box...
                  But look at the time you posted and the time I did... πŸ˜„
                  Cheers
                  Kim Frederik
                    djh
                    I tried to upload the model, but it says that it's too big to upload. How can I share it with you?
                      djh
                      One way to fix the problem is to copy and paste as a new file - the shadows are on the objects too.
                      • ely862meE
                        ely862me
                        You can upload up to 4mb. You can compress the file and it might get smaller. But for such a few geometry I wonder why the file exceeds 4mb ?
                        Most likely as Box said it is about the style you are using, in that case you could go to Window/Styles/Default styles and pick Simple style, and check the shadows back on. It should work.
                        When pasting the geometry in a new file, you get back to the Simple style which is a default style.
                        • BoxB
                          In the shadow settings dialog, have you unticked On Faces?
                            djh
                            [quote="ely862me"]
                            Didn't help.
                              djh
                              Yes, but it didn't help. The only method that helped was to copy and paste to a new file.
                              • jeff hammondJ
                                it's possible you've fiddled with the shadow light & dark settings..
                                  slbaumgartner
                                  Your picture suggests that you have nested groups. Have you enabled receive shadows on all the levels of nesting? A nested object will not receive shadows if its containing group does not.
                                    That's a good observation.
                                    @djh, you might try exploding all your groups and components to see what happens.
                                    You say, though, that copying the model to a new file fixed the problem. That might indicate you have a corrupted file.
                                      djh
                                      [attachment=1:1i2nw2cq]<!-- ia1 -->Screen Shot 2014-11-20 at 11.30.27 AM.png<!-- ia1 -->[/attachment:1i2nw2cq]
                                      [attachment=0:1i2nw2cq]<!-- ia0 -->Screen Shot 2014-11-20 at 11.30.43 AM.png<!-- ia0 -->[/attachment:1i2nw2cq]
                                      I did fiddle with them. Then, I fiddled with them again and again, but it only affected the shadows that were present. It didn't seem to restore the shadows on the objects.
                                        djh
                                        Sorry, I don't know what nesting is. All objects are on Layer0. I exploded all of the objects, but the shadows still don't appear on the objects.
                                          djh
                                          Yes.
                                            djh
                                            It probably is a corrupted file.
