    Off Screen Dialog.
    35 Posts 6 Posters 6.8k Views 6 Watching
    • KrisidiousK
      Krisidious
      Sketchup is not starting because of what I believe is an off screen dialog. Is there anyway to force it back to the main screen?
      By: Kristoff Rand
      • hellnbakH
        hellnbak
        Please define "off screen dialog"
        Yeah, I are dum
        • BoxB
          A dialog that is off the screen.
          Tig has a reg edit to reset them but I can't find it.
          • KrisidiousK
            Krisidious
            I can tell it's there because if I click anywhere I get the error donk noise.
            By: Kristoff Rand
            • KrisidiousK
              Krisidious
              you know, any pop up dialog box that you have to hit "ok" or put a key in or something.
              By: Kristoff Rand
              • BoxB
                Have you changed your screen setup?
                The low tech way is the move the screens around until you find it using the screen res settings.
                • KrisidiousK
                  Krisidious
                  Yeah, I've tried turning them off and changing resolution to use just one screen. but I can't find it anywhere. it's like it's actually off screen.
                  By: Kristoff Rand
                  • BoxB
                    Have a look at this.
                    http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=50344%26amp;p=454143%26amp;hilit=regedit#p454143
                    • D
                      driven
                      do either of these work?
                      Win + Tab shows all windows stacked and skewed.
                      Alt + Tab shows all windows side by side.
                      • KrisidiousK
                        Krisidious
                        Tried the regedit and had no effect.
                        tried win + tab and alt + tab. wintab cycled through all programs properly, but could not engage or find dialog.
                        alt-tab did not see SU at all.
                        strangely I can use other dialogs inside of SU, like the material or stlyes panels. but anything else makes the donk noise.
                        By: Kristoff Rand
                        • BoxB
                          I think that regedit was specifically for the preferences window.
                          I assume you've tried the reset workspace in preferences.
                          I'm sure tig will pop in with a full dialog reset regedit.
                          • KrisidiousK
                            Krisidious
                            reset workspace? nooooo... do you have any idea how many toolbars I have? all of them I think.
                            By: Kristoff Rand
                            • BoxB
                              It doesn't touch toolbars, only dialogs.
                              • KrisidiousK
                                Krisidious
                                Ok... I'm going to trust you.
                                By: Kristoff Rand
                                • KrisidiousK
                                  Krisidious
                                  I thought you meant tool bar reset button... nope. workspace reset didn't bring it up. this is freaky.
                                  this only happens if I try to remove the old live ivy from my su2015 plugins folder.
                                  By: Kristoff Rand
                                  • TIGT
                                    If Workspace reset doesn't work...
                                    Run Regedit...
                                    For Preferences off-screen dialog...
                                    Look in HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**PrefsPS**
                                    Set x and y values to 0 [dialog's top-left corner], IF they are bigger than the screen's x/y coords, or -ve values...
                                    Restart SketchUp...
                                    There are also about a dozen entries starting with 'Snappy'...
                                    e.g. HKEY_CURRENT_USER\Software\SketchUp\SketchUp 2015\**Snappy**Components
                                    These are the settings for the other dialogs.
                                    Open each in turn and look at the x and y values...
                                    Reset any suspicious ones as before...
                                    If a dialog has no x/y then it's never been opened [yet]...
                                    There's also one for the 'RubyConsoleDlg'...
                                    The Toolbar-Reset option is needed to sort out Toolbars, as its 'RubyWorkSpace' setup is not readily editable...
                                    • KrisidiousK
                                      Krisidious
                                      and no... what in the hell is going on here. It's because I want to use the new Live Ivy so bad... that's why this is happening.
                                      By: Kristoff Rand
                                      • TIGT
                                        I have also exchanged PMs with you...
                                        Why do you have a Plugins folder in ProgramData tree?
                                        What is adding the Gems folder to the $: ?
                                        πŸ˜•
                                        • KrisidiousK
                                          Krisidious
                                          Why do you have a Plugins folder in ProgramData tree? 3DxSketchUp.rb and ImaginationVisualizer.rb are in it... No idea why. I install all plugins to my main plugin directory.
                                          What is adding the Gems folder? uuidtools-2.1.4
                                          By: Kristoff Rand
                                          • TIGT
                                            Some 3rd party tools install into the ProgramData Plugins folder, with NO user choice [ill-advisedly!]: that folder is really intended for use on computers where several users share one Plugins folder... πŸ˜’
                                            OK, so no duplicated plugins installed in parallel folders... πŸ˜•
                                            There is no way that what is installed/loaded in one version of SketchUp should affect what is installed/loading in another version - unless there is some kind of shared Plugins folder setup between them...
                                            In your case it appears there is NOT !
                                            Obviously something is wrong...
                                            Have you tried Repairing/Reinstalling SUp v2015 ?
                                            πŸ€“
                                            • 1 / 2
