    SketchUp 2016 Wishlist
    192 Posts 69 Posters 102.4k Views 69 Watching
    • A
      ArtPen
      After SketchUp 2015 release, I want to take a moment to say “BIG” thanks for x64 support to a SketchUp Team.
      For SketchUp 2015 I did a long list, for SketchUp 2016 I think it is better to keep the program simple but provide a good core functionality and features.
      So I reduced my wish list to a minimum… well almost )
      GENERAL IMPROVEMENTS / FEATURES
      1. TeamWork / Xref - is essential for any office based work
        I know there is an option to use components, but common it is not really useable for commercial projects with team of 10 people. Or it is not flexible.
      2. Basic building elements - (Walls, Slabs, Curtain Walls, Roofs, Windows/Doors) with use of Dynamic Components, so user can edit individual elements and create custom elements.
      3. Faster Nicer Viewport - nicer texture representation, nicer anti-aliasing, soft shadows, smooth navigation, better fog and light. So there is no almost no need for external renderer
      4. Components to cut through walls / two faces - for creating windows and doors
      5. Real indestructible curves - even if curve was exploded you still have an option to find tangents or centre
      OSX
      Please give some love to a OSX version of SketchUP.
      1. Material List
      2. Better UI - Please update the UI to fit Apple UI guidelines (Flat design)
        Take a look at Pixelmator - the team make a great job
      3. Full Screen - Why it is still not here? Even Blender has it.
      4. Total area of material in Material Browser - Like in Windows
      WILL BE GOOD TO HAVE
      1. Line Types - like you have in Layout, All Layout library to SketchUp (Lines, Fills, Scrapbook)
      2. Layout and SketchUp Layers Sync - or option to export DWG from Layout with SketchUp layers.
      Cheers,
      • pbacotP
        Screen Shot 2014-11-09 at 11.42.30 AM.pngOh yes, and WHY do sections still look like this? Is it really an elementary impossibility to provide a graphic solid face option inside the native SU as everyone who has ever used SketchUp has always wanted?
        • L
          Lushi
          @jeff hammond said:
          @lushi said:
          The option to move objects without sticking together, as in AutoCAD, where the "Move" tool to differentiate the "stretch", and thus without a little more "groups" that accumulate in our models .
          that's a key difference between sketchup and other cad applications.
          in rhino, if you draw a line on top of another line, you'll have 2 lines.
          in sketchup, if you do the same thing, you'll have 1 line.
          both have advantages and i can't really say one way is better than the other.. you just have to have a slightly different mindset/approach in each program.
          i'm willing to bet this difference will remain for the life of the software(s).
          True, between sketchup and other programs there is a noticeable difference between uses and controls, but think about the possibility of having both functions in one software, you can have SU move default button, and an advanced button which can be separated without result in elimination of faces, keeping lines precindibles for them. is how to copy and then delete the original object, it seems a necessary tool.
          • A
            AirWindSolar
            Better snapping, even on small stuff.
            For example, I draw a section of 2x8" rectangular tubing with 1/16 wall thickness. (At the origin, totally orthogonal to the axes, so not even any odd angles to deal with yet.) I then try to grab a corner of that while zoomed in enough to clearly see the face of the cross section; it seems to be random whether it grabs the inside or outside corner, even when I can clearly see it's snapping to the corner not closest to the actual cursor location. I usually end up having to zoom in until I can't even fit the entire end of the tube on my screen to get it to snap to the outside corner so I can properly place the tube, then having to zoom out again to find where I needed to place it several feet away. Why it would choose the inside corner when the cursor is even right on the outside corner is beyond me.
            • oceanembersO
              oceanembers
              Modulus in dynamics... and just more dynamic functions in general
              • J
                JGA
                @hkla said:
                Decrease the minimum on Network licensing.
                How low? 2 would be nice. I have 6 potential users, who may jump between 7 computers depending on the task (one computer is a render or complex model computer for all to use). However, each user only uses the program in sparse bursts, only up to 3 at once, but I'm not allowed to have a network because 50 seats in a small office is insane. This becomes very annoying.
                I will gladly pay more per seat to unlock network licensing.
                We have a 3 user network license, originally purchased for version 6. I think new copies are still available.
                My wish - restore the fileserver based network license sharing, rather than the new web based version, as per my gripe on http://sketchucation.com/forums/viewtopic.php?f=15%26amp;t=59771
                Regards,
                JGA
                • chriC
                  chri
                  hi
                  It would be nice to have constraints like in SOLVESPACE soft ( from Jonathan Westhues ) to place object and animate a scene.
                  in french
                  Ce serai sympa de pouvoir ajouter des contraintes comme dans le programme SOLVESPACE de Jonathan Westhues pour placer des objets et les animer .
                  link :
                  http://solvespace.com/index.pl
                  linkage example :
                  http://solvespace.com/linkage.pl
                  french POST
                  http://sketchucation.com/forums/viewtopic.php?f=51%26amp;t=35686%26amp;start=450
                  Chri's example:
                  https://www.youtube.com/watch?v=J2udPIMtmJ0
                  Chri
                  • chriC
                    chri
                    @chri said:
                    hi
                    Chri
                    • TommyKT
                      TommyK
                      1. Animations for dynamic components to be saved per scene. For example, you could have a scene with doors all open, and a scene with all doors closed. Would make moving elements in Sketchup that much more presentable.
                      +1 👍
                      This would be a massive feature which would widen the scope for Sketchup. However, I think it could be delivered via a plugin, IF the Sketchup team were to implement a change to relative referencing of files and abandon the absolute reference approach:
                      • references to external components (via the "save [component] as..." and "reload..." commands) should be RELATIVE to the SKP file, as opposed to absolute references as is currently. If this change were made, a plugin could be made to do what you are thinking. In fact, I may start putting something together today...
                      • also, in Layout, use relative references. It just works better if you are using things like Dropbox, or indeed any shared folder. Absolute references and working across several workstations is a pain. It is not how most people's project folders are organised.
                      [EDIT] it turns out TIG has already made a plugin that is very similar to what we are talking about: http://sketchucation.com/forums/viewtopic.php?t=7329
                        I got the main item, 64 bit and am over the moon with that. Better control over these pesky additional geometries and additional operations would be nice. Also, fix the windows explorer crashing thing 'cos being unable to import additional modules etc is a PITA. Better handling of graphics and textures would also be really nice but I am being careful what I ask for right now as I have my Christmas present early.
                        • W
                          wawmsey7
                          multi core processing for complex dynamic component calculations!
                          • A
                            Atrian
                            I've been trying to get network licences since version 8 (and I've wanted just 3 as well). I've been on the phone with multiple customer service reps of varying levels of expertise, and all have told me it isn't possible unless I buy 50. Maybe it was discontinued after 6 and you've been able to be grandfathered into the new standards? If not, I would love to know who I need to talk to so I can upgrade our licenses to network.
                            -Amanda (hkla)
                            • pbacotP
                              Funny thing, moving into 2015, this no longer happens to me. (SU asking me to save untouched untitled stationery). But I have many plugins yet to load. We'll see.
                              • D
                                driven
                                @baz said:
                                ...I wish Su wouldn't ask me if I want to save an untouched/unedited file, just close it!
                                that is from a plugin...
                                something is adding Materials or components to the model on start...
                                check your material/component browser, if your happy for this plugin to 'expect' it's items to always be available, then save as Template to include them in all models...
                                or turn the plugin off until you want to use it...
                                john
                                • bazB
                                  baz
                                  john
                                  You were right about materials and components, but I purged and saved as new template, same same.
                                  Also if you open a working file and close it without doing anything, you are still asked if you want to save. None of my other soft does that.
                                  • jeff hammondJ
                                    jeff hammond
                                    it's usually the rendering plugins that cause this behavior.. what's your renderer?
                                    (for me, it's skindigo.. i just turn it off in extensions until i need to use it.. this will prevent the plugin from doing 'something' to the new file.)
                                    dotdotdot
                                    • bazB
                                      baz
                                      Hey thanks guys, it was Twilight was the culprit.
                                      • bazB
                                        baz
                                        Couple of small things...
                                        (Solved, this was caused by a plugin, see posts below).
                                        And I wish that the Materials and Components browsers would allow scrolling with the mouse wheel rather than the side scroll bar.
                                        • nghminh81N
                                          nghminh81
                                          I really really wish that Skethchup 2016 would have Real time Ambient occlusion! That would save some years in my life from rendering works.
                                          • D
                                            driven
                                            @baz said:
                                            ...And I wish that the Materials and Components browsers would allow scrolling with the mouse wheel rather than the side scroll bar.
                                            @baz
                                            I should have read both, this one is simple to fix...
                                            buy a mac...
                                            it does that already...
                                            john
                                            • 9
                                            • 10
                                            • 3 / 10
