    SketchUp 2016 Wishlist
    192 Posts 69 Posters 67.0k Views 69 Watching
    • jujuJ Offline
      juju
      @mariocha said:
      Repeated BUGSPLATs, on Windows 7 under Parallels. 😕
      that's not on my wishlist for SU2016, but hey, each to their own...
      and yes
      I realise
      you were
      commenting
      on the post
      directly
      above yours,
      it would help
      if you
      quoted them,
      for context
      • N Offline
        numerobis
        A divide (line) function without limitation to 100 segments... 😒
        • pbacotP Offline
          Not so hard to type the number, but whatever you think is important.
          • srxS Offline
            srx
            TRIMBELE VR headset and SketchUp! I think that it would be great step forward if Trimble would integrate VR interface in new Sketchup 2016, which would be used for modeling! Trimble VR hardware could be in the packet too 😄
            www.saurus.rs
            • mariochaM Offline
              mariocha
              removed
              %(#008000)[Mario C.
                mojtaba691001
                دِ این لامصبو بدین بیرون دیگه
                اینقد روی اعصاب ما راه نرین
                WHEN do Dear Trimle release Sketchup 2016?? when??
                atleast tell us new version date,PLEAAAAAAAASE
                  WHEN do Dear Trimble release Sketchup 2016?? when??
                  at least tell us new version date, PLEAAAAAAAASE
                  This is not the official Sketchup site.
                  If it were then you would not be told such sensitive information anyway.
                  That said, the annual release of new versions of SketchUp have in recent years moved to just before the year changes.
                  So whilst it is in no way a guarantee, you might hope to see v2016 available within the last few months of 2015...
                  BUT you'll just have to be patient. 😞
                  • pbacotP Offline
                    "Save a copy as" on Mac: This would be useful for saving versions for other users/ colleagues who are not up to date. That way you could remain in your version of the drawing while sending off a copy. But alas the version options are missing from this save dialog.
                    • N Offline
                      numerobis
                      Yes, you're right. I can do this. But it doesn't display the length calculation for more than 100 segments. So in many cases where i need a specific length it's try and error. Sure, i can do the calculation by hand (i have to do it this way now), but the interactivity is really helpful in many cases. A variable would be great, so that you can set the limit as you like/need it.
                      One more general wish...
                      A "cancel" button or better the ESC-key that simply works on EVERY Ruby action. Many times an operation gets stuck or can run forever, e.g. with an accidentally wrong selection. And then the only option is to shut down SU. Not very elegant... and very annoying if the last autosave is missing some important changes...
                        Brighter3D
                        Faster "save all textures" from the api.
                        It would speed up all renderers export time...
                        Best Regards,
                        brighter3d.com
                        • jgbJ Offline
                          jgb
                          I asked about this a long while back and the answer from one of the Ruby Magicians is the the Ruby API does not poll the keyboard during certain operations, so it never sees the ESC key (or any other) and cannot exit a perpetual loop.
                          jgb
                            I would like..... Pretty please.
                            1. Produce a proper set of extrusion tools that is not just intended for flash roof building and can act the same as a cad program.
                            2. Finally get rid of the extra facets and lines.
                            3. Make a proper method of allowing close up view of components and groups for editing, WITHOUT clipping problems.
                            I understand there are several plugins for the extrusion problem but they are limited.
                            Oh, and 4. Continue to make the program more stable rather than adding extra functions.
                            • 6
                            • 7
                            • 8
                            • 9
                            • 10
                            • 10 / 10
