    [REQ]Auto Perspective
    17 Posts 5 Posters 2.0k Views 5 Watching
    • Rich O BrienR Online
      Is this possible?
      If I have Ortho Front/Left/Right..... view in SU and I orbit it immediately change to perspective?
      I do have shortcuts assigned for Perspective and Ortho but having Sketchup detect that I want to view in Ortho but swap back to Perspective on orbit would be a nice feature.
        Cool idea. I could use that.
        • K Offline
          kaas
          Sounds like a job for the 'toolObserver' & id nr 10508 (CameraOrbitTool).
            driven
            do you have a shortcut for 'Camera' >> 'Previous', and is that the behaviour your looking for?
            john
            • JQLJ Offline
              JQL
              I can see the point but I have a shortcut for camera perspective. It toggles perspective on and off and it's very convenient to me... also for dealing with the famous clipping issues one has some times...
              www.casca.pt
              Visit us on facebook!
                I too toggle but I am used to Blenders auto perspective mode.
                Snapping out of ortho on orbit seems a logical move.
                Unless you need to zoom in very close.
                • K Offline
                  kaas
                  It's a great idea so I had a go and it seems to work under Windows.
                  Save this code as a .rb file and drop it into the plugins folder. I'm a Ruby newby so it might violate proper code habits but feel free to comment.
                  require 'sketchup.rb'
                  module MB
                  class OrbitToPerspectiveObserver < Sketchup;;ToolsObserver
                  	def onActiveToolChanged(tools, tool_name, tool_id)
                  		if tool_id==10508
                  			camera = Sketchup.active_model.active_view.camera
                  			status = camera.perspective?
                  			if !status
                  				camera.perspective = true
                  class OrbitAppObserver < Sketchup;;AppObserver
                  	def onNewModel(model)
                  		model.tools.add_observer(OrbitToPerspectiveObserver.new)
                  	def onOpenModel(model)
                  Sketchup.add_observer(OrbitAppObserver.new)
                  end #module
                  edit: changed the code so it will now auto-start when Sketchup starts OR a new file is made. Note: double-clicking on a file in windows explorer will not get noticed by these observers
                    driven
                    on the mac, orbit automatically switches to perspective and remains there, doesn't that happen on a PC?
                    john
                      If I am in ortho and orbit i remain in ortho
                        john
                        I don't see that on my Mac. When I orbit the view shows an isometric view but it is still parallel projection.
                          driven
                          If I am in ortho and orbit i remain in perspective
                            This is what I see on my Mac:
                            Front view.
                            After orbiting.
                            After manually switching camera to Perspective .
                              driven
                              I select Menu >> Camera >> Parallel Projection
                              I Orbit
                              I check Menu >> Camera : Perspective is selected
                              are you seeing something else??
                              EDIT: I had left the code from above active when I started test, it causes Perspective to 'Stick'
                              john
                                @john
                                paralell remains....
                                  click that image to play it
                                    driven
                                    your to quick dave I edited my question because
                                    oops and thanks
                                    john
                                    • JQLJ Offline
                                      JQL
                                      What did you use to do this Image Rich. It would help in a project I'm developing... πŸ˜„
                                      www.casca.pt
