    Pulling A Bar Between 2 Objects
    5 Posts 4 Posters 366 Views 4 Watching
    • O
      oo7ml
      Hi, is it possible to pull a circle pole / bar between two pillars (or should i say what is the best way 😄
      I have not problem in pulling the circle poll out of object A, but how do i get it to snap to the far object B surface, baring in mind that there is no other object inline with object B, so i can't use another object face for reference.
      I've attached a quick image of what i mean.
      http://s29.postimg.org/cido4903r/pulling.png
      Thanks in advance for your help.
        With Push/Pull you can pull out the circle and move the tool to a corner on the opposite post. You don't have to keep the Push/Pull tool on axis since it only operates in the direction of the face's normal.
        • Wo3DanW
          Wo3Dan
          @dave r said:
          With Push/Pull you can pull out the circle and move the tool to a corner on the opposite post. You don't have to keep the Push/Pull tool on axis since it only operates in the direction of the face's normal....
          Also, you can benefit from turning ON X-Ray face style. This way you can even snap to endpoints through faces if no proper endpoint is in sight without X-ray.
          • O
            oo7ml
            Great,excellent, thanks guys... and thanks for providing an example too.
            • TIGT
              Also use separate components to contain the 'parts' - this helps avoid overlaid geometry sticking together where you don't want it to - e.g. in subsequent Moves etc...
