    VRay Lighting - Light color
    renderpluginsextensions
    8 Posts 4 Posters 791 Views 4 Watching
      coreymurray
      Hi all
      SU2014, VfS 2 Sp1
      I am trying to create some colored rope lights - see image.
      I have placed an area light inside a colored bulb, which uses a 'standard' material with diffuse color and transparency.
      I am wondering why the light on the wall is still white, and why it isn't being tinted by the material that it is passing through.
      I guess i could change the color of the area light, but was hoping to retain control of all bulbs via the base component, i.e. same bulb in all lights
      Any ideas or comments would great!
      Cheers
      • majidM Offline
        majid
        Better to use a light emitter material for the light bulbs to mimic the colored bulbs, with the same amount of intensity IMO.
        • jiminy-billy-bobJ Offline
          jiminy-billy-bob
          You can easily do that using a 2sided material (so you keep only one light type)
            coreymurray
            Thanks Jiminy - that worked a treat.
            Can anyone expand on why? I thought the material was double sided before (double sided tick box in option in mat editor).
            The other thing that worked was adding a refractive layer and changing the refraction colour
            Cheers
            Corey
              coreymurray
              Thanks Majid - That's a nice simple solution, i was quite keen on the fall-off/shading on the bulbs which i couldn't replicate with emissive material.
              • andybotA Offline
                andybot
                that's looking nice! The double-sided material gives you translucency.
                  jiminy-billy-bob
                  This tick box only means that the material will be applied to both sides of the polygons.
                  A Vray2sided Mtl is a really special material. It allows you to have different materials between the front and back sides of your polygons, and blend these two materials together (and the light they receive) depending on a grey value (or map).
                  This allows you to mimic translucency for very thin objects (one face only): Paper, leaves, curtains, etc.
                  https://www.google.fr/webhp?#q=vray%202sided
                    coreymurray
                    Thanks for the explanation Jiminy - that's a really powerful technique.
