    [REQ] Clay mode
    18 Posts 10 Posters 4.8k Views 10 Watching
    • soloS
      solo
      I need a plugin so I can change all materials except any with transparency to a clay color.
      Anyone?
      http://www.solos-art.com
        Doesn't Renderiza have a suite of tools that does this?
        • J
          Jim
          Blackout can easily be updated to work. On line 42, change 'Black' to 'Gray' for example.
          http://sketchucation.com/forums/viewtopic.php?t=15790
          I've PM'd you "ClayOut"
          Wait, what color is Clay?
          • soloS
            solo
            Off white, slight beige.
            • J
              Jim
              "Beige" it is. check PM.
              • soloS
                solo
                That works great, however it does not make the default SU material also beige, is it possible to do that too?
                • soloS
                  solo
                  What if the clay color can be the same as the SU default color (as set by user)?
                  • PixeroP
                    Pixero
                    Perhaps TIGs Global Material Changer could be used?
                    Not sure how to change all materials exept glass automatically though.
                    Maybe a tweak from TIG?
                    The bad thing is that it will be destructive.
                    A "Material override" checkbox i Thea (working with Presto) would be better though...
                    • JQLJ
                      JQL
                      Couldn't the greyscale plugin be easily adapted to a custom color? It works great for turning on and off greyscale.
                      Here it is (untested on 2014):
                      http://www.smustard.com/script/GreyScale
                      www.casca.pt
                      Visit us on facebook!
                      • utilerU
                        utiler
                        Hey Pete, Podium has a simple 'Clay' mode by choosing default SU face colours...
                        Just Curious...
                        • cottyC
                          cotty
                          Maybe you can group all objects and paint it with the same color from outside the group to replace the color for the non-painted faces?
                          my SketchUp gallery
                          • olisheaO
                            olishea
                            can i ask why not just use clay mode in thea?
                            oli
                            • soloS
                              solo
                              Because it is not supported in Presto, only BSD
                              • olisheaO
                                olishea
                                oh ok. shame because i love that mode. saying that, i cant even use presto on my mac lol 😆
                                oli
                                • J
                                  Jim
                                  I thought I removed GreyScale from Smustard. Please don't download that version. The Smustard version is scrambled and relies on other files. The later version is a single file and has no dependencies.
                                  I'll get GreyScale in the Plugins Store after it is cleaned up.
                                  Actually, GreyScale already has a Front Face mode which assigns all materials to the current default face color. All i need to add is the alpha filter. I've sent a PM.
                                  • romboutR
                                    rombout
                                    Why a PM and not a post here? or change that plugin on smustard?
                                    • JQLJ
                                      JQL
                                      I did think it had that mode but I've not used it for so long...
                                      Problem with thea is that only the preset materials or materials with diffuse set to sketchup texture will render white or frontface mode...
                                      www.casca.pt
                                      • Al HartA
                                        Al Hart
                                        Coincidentally I posted a clay image on my blog today:
                                        http://1.bp.blogspot.com/-BTWKBkuw1Lo/U4NVuL9QiWI/AAAAAAAABwE/mSKXSaNlMhk/s1600/Bathroom-clay2.jpg
                                        (Rendered with IRender nXt using the Clay Rendering option)
                                        The sketchy edges do not reflect in the mirror properly. We have another option to render edges which would handle reflections properly, but it only works with non-sketchy edges. If you want Sketchy edges - it is best not to include this obvious of a reflection.
                                        Al Hart
                                        http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30).PNG
                                        IRender nXt from Render Plus
