๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[REQ] Clay mode
18 Posts 10 Posters 3.9k Views
    I need a plugin so I can change all materials except any with transparency to a clay color.
    Anyone?
      Doesn't Renderiza have a suite of tools that does this?
        Jim
        Blackout can easily be updated to work. On line 42, change 'Black' to 'Gray' for example.
        http://sketchucation.com/forums/viewtopic.php?t=15790
        I've PM'd you "ClayOut"
        Wait, what color is Clay?
          Off white, slight beige.
            Jim
            "Beige" it is. check PM.
              That works great, however it does not make the default SU material also beige, is it possible to do that too?
                What if the clay color can be the same as the SU default color (as set by user)?
                  Pixero
                  Perhaps TIGs Global Material Changer could be used?
                  Not sure how to change all materials exept glass automatically though.
                  Maybe a tweak from TIG?
                  The bad thing is that it will be destructive.
                  A "Material override" checkbox i Thea (working with Presto) would be better though...
                    JQL
                    Couldn't the greyscale plugin be easily adapted to a custom color? It works great for turning on and off greyscale.
                    Here it is (untested on 2014):
                    http://www.smustard.com/script/GreyScale
                    www.casca.pt
                    Visit us on facebook!
                    • U Offline
                      utiler
                      Hey Pete, Podium has a simple 'Clay' mode by choosing default SU face colours...
                      purpose/expression/purpose/....
                        cotty
                        Maybe you can group all objects and paint it with the same color from outside the group to replace the color for the non-painted faces?
                        my SketchUp gallery
                        • O Offline
                          olishea
                          can i ask why not just use clay mode in thea?
                          oli
                            Because it is not supported in Presto, only BSD
                            • O Offline
                              olishea
                              oh ok. shame because i love that mode. saying that, i cant even use presto on my mac lol ๐Ÿ˜†
                              oli
                                Jim
                                I thought I removed GreyScale from Smustard. Please don't download that version. The Smustard version is scrambled and relies on other files. The later version is a single file and has no dependencies.
                                I'll get GreyScale in the Plugins Store after it is cleaned up.
                                Actually, GreyScale already has a Front Face mode which assigns all materials to the current default face color. All i need to add is the alpha filter. I've sent a PM.
                                • romboutR Offline
                                  rombout
                                  Why a PM and not a post here? or change that plugin on smustard?
                                    JQL
                                    I did think it had that mode but I've not used it for so long...
                                    Problem with thea is that only the preset materials or materials with diffuse set to sketchup texture will render white or frontface mode...
                                    www.casca.pt
                                    • Al HartA Offline
                                      Al Hart
                                      Coincidentally I posted a clay image on my blog today:
                                      http://1.bp.blogspot.com/-BTWKBkuw1Lo/U4NVuL9QiWI/AAAAAAAABwE/mSKXSaNlMhk/s1600/Bathroom-clay2.jpg
                                      (Rendered with IRender nXt using the Clay Rendering option)
                                      The sketchy edges do not reflect in the mirror properly. We have another option to render edges which would handle reflections properly, but it only works with non-sketchy edges. If you want Sketchy edges - it is best not to include this obvious of a reflection.
                                      Al Hart
                                      http://wiki.renderplus.com/images/e/ef/Render_plus_colored30x30%29.PNG
                                      IRender nXt from Render Plus
