    [REQ] Clay mode
    18 Posts 10 Posters 4.8k Views 10 Watching
      Jim
      "Beige" it is. check PM.
      • soloS
        That works great, however it does not make the default SU material also beige, is it possible to do that too?
        • soloS
          What if the clay color can be the same as the SU default color (as set by user)?
          • PixeroP
            Pixero
            Perhaps TIGs Global Material Changer could be used?
            Not sure how to change all materials exept glass automatically though.
            Maybe a tweak from TIG?
            The bad thing is that it will be destructive.
            A "Material override" checkbox i Thea (working with Presto) would be better though...
            • JQLJ
              JQL
              Couldn't the greyscale plugin be easily adapted to a custom color? It works great for turning on and off greyscale.
              Here it is (untested on 2014):
              http://www.smustard.com/script/GreyScale
              www.casca.pt
              Visit us on facebook!
              • utilerU
                utiler
                Hey Pete, Podium has a simple 'Clay' mode by choosing default SU face colours...
                Just Curious...
                • cottyC
                  cotty
                  Maybe you can group all objects and paint it with the same color from outside the group to replace the color for the non-painted faces?
                  my SketchUp gallery
                  • olisheaO
                    olishea
                    can i ask why not just use clay mode in thea?
                    oli
                    • soloS
                      Because it is not supported in Presto, only BSD
                      • olisheaO
                        olishea
                        oh ok. shame because i love that mode. saying that, i cant even use presto on my mac lol 😆
                        oli
                          Jim
                          I thought I removed GreyScale from Smustard. Please don't download that version. The Smustard version is scrambled and relies on other files. The later version is a single file and has no dependencies.
                          I'll get GreyScale in the Plugins Store after it is cleaned up.
                          Actually, GreyScale already has a Front Face mode which assigns all materials to the current default face color. All i need to add is the alpha filter. I've sent a PM.
                          • romboutR
                            rombout
                            Why a PM and not a post here? or change that plugin on smustard?
                            • JQLJ
                              JQL
                              I did think it had that mode but I've not used it for so long...
                              Problem with thea is that only the preset materials or materials with diffuse set to sketchup texture will render white or frontface mode...
                              www.casca.pt
                              • Al HartA
                                Al Hart
                                Coincidentally I posted a clay image on my blog today:
                                http://1.bp.blogspot.com/-BTWKBkuw1Lo/U4NVuL9QiWI/AAAAAAAABwE/mSKXSaNlMhk/s1600/Bathroom-clay2.jpg
                                (Rendered with IRender nXt using the Clay Rendering option)
                                The sketchy edges do not reflect in the mirror properly. We have another option to render edges which would handle reflections properly, but it only works with non-sketchy edges. If you want Sketchy edges - it is best not to include this obvious of a reflection.
                                Al Hart
                                IRender nXt from Render Plus
