    MSPhysics 1.0.3 (16 October 2017)
    927 Posts 171 Posters 1.1m Views 172 Watching
      tomasz
      @anton_s said:
      Yes rombout, its windows only. Furthermore, it's unstable and incomplete.
      I wish you developed it further or at least made it stable.
      Here is my quick try with Thea. Maybe it will motivate you slightly πŸ˜„
      Thea Render - Shadow Catcher + IBL
      • soloS Offline
        solo
        πŸ˜„
        Tomasz!! you tease.
        http://www.solos-art.com
          Another brick on the wall! πŸ˜„
            RobiBue
            Hi, I'm using SU2015 and with
            ams_Lib 3.1.2 and
            MSPhysics 0.2.1
            I get the following errors:
            [pre:16r2j6vf]Error Loading File C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb
            Error: #<NameError: uninitialized constant AMS::FFI>
            C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:10:in <module:SDL>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/sdl.rb:4:in <top (required)>'
            C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
            C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics/main.rb:39:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
            C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in register_extension'
            C:/Users/[User Name]/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:106:in <module:MSPhysics>' C:/Users/*[User Name]*/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/MSPhysics.rb:88:in <top (required)>'[/pre:16r2j6vf]
            Please help
            thanks
            • luckyvacL Offline
              luckyvac
              hello, I can not seem to find a tutorial to create joint . I use SketchyPhysics . I've the table IU but not the icons .
              Where are the joints ???
              Thanks for your help.
              i've 0.2.0 it's worry ?
              jean-luc
                Anton_S
                MSPhysics will be up and running soon. Have a great holiday!
                  Anton_S
                  Hi, 0.3.0 Alpha has been released! Go to first post for download.
                  Changelog:
                  • Reverted to SDL1 and SDL_Mixer1, which fixed the crash that occurred after using SketchUp for a few minutes.
                  • Optimized the C++ extension.
                  • Upgraded to Newton 3.14.
                  • Added joints. Still more work to go.
                  • Added replay animation tool. It can record materials and emitters.
                  I might post videos regarding the features soon. Meanwhile, try out the chains.
                  chains.skp
                  • cottyC Offline
                    cotty
                    Tried with SU16-64 Win8.1-64:
                    my SketchUp gallery
                      Anton_S
                      Try deleting the old version and download the new one. It might be bragging about localization, but in theory it shouldn't.
                      • cottyC Offline
                        cotty
                        I've compared my installed files with the zip and there were some files missing in my installation. Now it's working perfect, thank you!
                        click to animate
                        my SketchUp gallery
                        • cottyC Offline
                          cotty
                          I like the debug modus of your chain model πŸ˜‰
                          click to animate
                          my SketchUp gallery
                          • cottyC Offline
                            cotty
                            How can these (groups of) bodies collide? If the lower group is exploded, the individual parts collide but not as a group/component.
                            click to animate
                            coll_example.skp
                            my SketchUp gallery
                            • cottyC Offline
                              cotty
                              If I assign the hinge to the ground instead of the group of objects, the collision works, but I need the assignment to that group for this case:
                              coll_example2.skp
                              my SketchUp gallery
                                Anton_S
                                Cotty, joint properties can be editted. Select the desired joint, open MSPhysics UI, and enable 'connected collide' option.
                                • cottyC Offline
                                  cotty
                                  Thank you, Anton, that helped!
                                  my SketchUp gallery
                                    RobiBue
                                    Just a heads up replying to my post:
                                    ams_Lib 3.1.2 and
                                    MSPhysics 0.2.1
                                    [pre:1doxyosj]Error Loading File ...[/pre:1doxyosj]
                                    Please help
                                    thanks
                                    Thank you,
                                    the new version "0.3.0" runs smoothly on SU 15 and 16
                                    Great work ❗ πŸ‘
                                    • P Offline
                                      PituPhysics
                                      Hello Anton! For me it's not working. New installed SU16-x64 and AMS 3.1.3.
                                      http://sketchucation.com/forums/download/file.php?mode=view%26amp;id=135827
                                      • F Offline
                                        faust07
                                        Initial tests are promising. Great work Anton! πŸ‘ I can not resist to carry out detailed experiments with joints and scripts. Extreme wishes are an import function for SketchyPhysics models and detection of replay data by the Twilight renderer. 😐
                                        • P Offline
                                          PituPhysics
                                          I'm sorry, my fault. 😞 Now work perfectly πŸ‘
                                            Seems terrific! 😎
                                            Nothing for multi-Languages System ?
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
