    [Plugin] AMS Library 3.7.1b (29 May 2021)
    107 Posts 38 Posters 630.3k Views 38 Watching
      April Zylith
      MSPhysics_v1.0.3 does not work on SU 2019.
      What should I do?
      System:
      OS: Windows 10 Pro 64 bit.
      App: Sketchup Pro 2019 64 bit.
      When open SU 2019, Showing These errors.
        What should I do?
        You're right. It doesn't work. What can you do? Be patient. The author has been working on an update and will release it when it is ready.
        • Y Offline
          young77
          Hi...
          I just want to make sure is this plugin doesnt work for sketchup 2021 ?
          is there any possible way to make this enable to run in skp 2021 ?
          thanks,
          Hp
          • P Offline
            pipinek
            @young77 said:
            Hi...
            thanks,
            Hp
            Splendid plugin,
            any updates for SSU 2021. Even paid?
            Thank you in advance if any
            • Q Offline
              qifu123
              I need some help, AMS Library 3.6.0h In sketchup 2021 error
              载入文件 C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb 时出错
              Error: #<IOError: The required, staged c extension file, "C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.7/ams_lib.so", is missing!>
              C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:204:in block in require_all' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in each'
              C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:201:in require_all' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/main.rb:148:in <top (required)>'
              C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in load'
              C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in register_extension' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:32:in module:Lib'
              C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:7:in <module:AMS>' C:/Users/Administrator/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib.rb:5:in <top (required)>'
              • P Offline
                pibuz
                Same here. AMS lib is not compatible with SU2021, or so it seems..
                It's a pity.. 😞
                WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                • W Offline
                  wikii
                  AMS lib is not compatible with SU2021.
                    Anton_S
                    Updated for 2021
                    • F Offline
                      Francis sket master
                      Dear Anton_S
                      After installation of MSPhysics & AMS Library by sketchUcation extensionstore v4.1.0 following is the error message keep pops up as I start sketchup pro 2021. Anticipating your answer with solutions. Thank you very much in advance.
                      C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb file load error
                      Error: #<IOError: The required, staged c extension file, "C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.7/msp_lib.so", is missing!>
                      C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:219:in block in require_all' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in each'
                      C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in require_all' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                      C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require' C:/Program Files/SketchUp/SketchUp 2021/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:92:in require'
                      C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in require'
                      C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in load' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                      C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/bernard/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                        DeKlusser
                        I am only getting a lot of errors like:
                        Error Loading File C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb
                        Error: #<IOError: The required, staged c extension file, "C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/libraries/stage/win64/2.7/msp_lib.so", is missing!>
                        C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:219:in block in require_all' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in each'
                        C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/ams_Lib/extension_manager.rb:216:in require_all' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main.rb:70:in <top (required)>'
                        C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics/main_entry.rb:15:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in require'
                        C:/Program Files/SketchUp/SketchUp 2021/Tools/extensions.rb:197:in load' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in register_extension'
                        C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:21:in <module:MSPhysics>' C:/Users/Simon/AppData/Roaming/SketchUp/SketchUp 2021/SketchUp/Plugins/MSPhysics.rb:5:in <top (required)>'
                          Your load errors come from MSPhysics which does not work in SketchUp 2021. Anton has indicated he's working on an update but he hasn't released it yet.
                          Your profile says you are still using Sketchup 2018. Please update that information. Thanks.
                            Beltrama01
                            I'm looking forward to an update to run MSPhysics in sketchup 2021
                            • X Offline
                              xaliuyi Newcomers
                              this plugin is very good:thumb:
                                rcatedra
                                Hello all. I'm using this plugins since 2015 and it's amazing. Now i'm learning an advanced programming features, and I noticed when I uses for instance the key ('a') function into an slider controller, I have the following error (ruby console): "Nomethoderror: undefined method 'key' for AMS::Keyboard:Module"
                                I attach a picture to see my settings. Any clue about this? I've tried to uninstall and install the AMS library and msphysics several times. I have Sketchup 2016 version and the 3.7.1b AMS version
                                Thanks on advance!
                                • W Offline
                                  wikii @Anton_S
                                  @Anton_S
                                  AMS lib is not compatible with SU2024.
                                  Will you update it?
                                  K 1 Reply Last reply Reply Quote 0
                                  • K Offline
                                    kuikeil @wikii
                                    @wikii My extension also uses this lib, and I urge the author to make it compatible with 2024.
                                      Rich O Brien Moderator @kuikeil
                                      @kuikeil Anton is aware that some of his tools need updating.
                                      • Dan RathbunD Offline
                                        Dan Rathbun
                                        FYI, SketchUp has migrated to using the Qt GUI framework libraries. So, in many cases it is no longer possible to use the Windows SDK system calls to tweak SketchUp interface objects.
                                        I'm not here much anymore.
                                        R 1 Reply Last reply Reply Quote 0
                                          rcatedra @Dan Rathbun
                                          @Dan-Rathbun
                                          Hi Dan, so do you think this should be the reason the keyboard is not working anymore? I saw some videos of people using SU2016 with the same version and they are able to use the keyboard.... let me know.
                                          Dan RathbunD 1 Reply Last reply Reply Quote 0
                                            Dan Rathbun @rcatedra
                                            @rcatedra I myself do not use this library. So, I cannot say for sure.
                                            But the error given is that the module does not respond to a method named "key".
                                            If it did respond to this method in the past under older SketchUp versions, then the reason for SU2024 is that an error during loading prevented the module code from defining its methods.
                                            • 6
                                            • 5 / 6
