    [Extension][$] iSelect
    54 Posts 20 Posters 27.1k Views 20 Watching
    • renderizaR Offline
      renderiza
      @erikb said:
      But auto-install with sketchUp plugin manager (I even tried it twice) doesn't install it ?
      Am I missing something, or is something missing 😉 ?
      Have you verified that your plugin folder's permission have full rights?
      Just in case try auto-installing it from Extension Warehouse to see if that works.
      [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
        Thanks for this plugin. I think it'll be very useful.
        Erik, I just auto-installed it with the Plugin Store and it worked just fine for me.
        • erikBE Offline
          erikB
          Windows keeps being a mystery to me. 😒
          Not so long ago Tig mentioned the fact that being logged in as administrator not necessary meant you had full rights on every directory. So in order to overcome this he suggested all the usual directory's (sketchup, plugins,..) should all have this full admininstrator rights attributed to them. I don't recall anymore according to which plugin this was mentioned. BUT I then made sure all rights where given, and in the end the plugin worked. Seems that, for what ever reason (microsoft?) this now isn't anymore the case (altough all the other plugins work), for the plugin folder!
          So again I changed the rights and "hoera !!" it works.
          And may I say, fantastic plugin !!! So often when moving things (even after checking in x-ray mode) you missed a face of a vertex in the background and therefor messed up your model whit out noticing it. And when you found out later there is so much correction to be done (or some times it is virtual impossible timewise).
          So 👍 🎉 👍 for this great plugin. (not to mention some other great plugins you made) Thanks,
          erikB
          • deaneauD Offline
            deaneau
            Really usefull.
            what do you think about a plugin that can do following:
            i have an object with inner and outer faces. i would have a plugin that select only outsidefaces.
            look here
            http://sketchucation.com/forums/viewtopic.php?f=323&t=38493
            scroll down to
            http://sketchucation.com/forums/viewtopic.php?f=323&t=38493#p340407
            thankyou for this plugin
            dean
            MADE, BORN AND LIVING IN BERLIN
            Big Thank You to all Programmers
            Some German words are so long that they have a perspective. M.Twain
            • G Offline
              glro
              @renderiza said:
              [pre]Authors:: Renderiza
              [*]Group & Component selection is fixed
              [/color]
              yes
              it works better, thank you...
              there seems to be still some problems
              selection from top
              selection from tp
              this is what is selected from another point of view
              selection before iselect
              after clicking on "iselect" button, some columns remain selected
              as i understand the rule (a component which is not totally visible is excluded from the selection), this shouldn't happen, no?
              selection after iselect
                Seems there is a glitch! 😉
                Each 3d block is a group! I select in side view!
                Seems don't works when I all select 1 or all select 2 from left to right or right to lerft! 😲
                All stay selected after click the black eye!(in perspective or parallal projection) 😮
                v6.skp
                • G Offline
                  glro
                  @renderiza said:
                  [pre:1w1z3q12]Authors:: Renderiza
                  Plugin Name:: iSelect
                  Version:: 1.0.1
                  Date:: 11/6/2013
                  Cost:: Free[/pre:1w1z3q12]
                  iSelect v1.0.1 is now available for download.
                  http://jroot.sketchucation.com/pluginrepo/image/RND_iSelect_v1.0.0.png
                  %(#909090)[What is new:
                  • Group & Component selection is fixed
                  • Context Menu Added (right click > iSelect)
                  • Add keyboard shortcut
                  How to set keyboard shortcut:
                  Window > Preference > Shortcuts > Function = Edit/Item/iSelect > Add Shortcut
                  Thanks for Feedback! 👍]
                  i use Iselect 1.0.1 to select components, but sometimes i forget to clic on the plugin button after selecting to filter them
                  i wouldn't forget if the filtering was automatic after selection
                  so would it be possible modify the order of operations, and embed your plugin in a "filtered selection" tool:
                  you click on the button corresponding to "filtered selection"
                  you select
                  and only then "iselect" is launched to filter the selection
                  i tried to add some lines of code to yours to do that, but after calling the native select tool, everything stops ...
                  • danchoD Offline
                    dancho
                    does someone use it under SKP 2015. I can't get it to work 😒
                    • E Offline
                      Einstein
                      Hi!
                      As you can see in the attachment, it also deselects some of the front, visible faces. The problem appears when softened edges come into play.
                      I also told this in Extension Warehouse.
                      • G Offline
                        glro
                        @renderiza said:
                        I have updated the code of 'iSelect' and the new version 2.0.0 is available at the following link...
                        Also, I'll appreciate more feedback so I can improve iSelect even more.
                        Note: I am charging a small fee for the plugin to help me spend more time making SketchUp Extensions.
                        best regards,
                        Renderiza
                        i tried version 2
                        still have problems
                        Error: #<RangeError: float Inf out of range of integer>
                        C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'
                        selection is not filtered
                        • G Offline
                          glro
                          @renderiza said:
                          best regards,
                          Renderiza
                          something is missing?
                          content 1
                          content 2
                          i don't see the code that is supposed to do the job
                            renderiza
                            Can you provide an attachment of the SketchUp model you are trying to use?
                            What version of SketchUp are you using?
                            Can you install the plugin?
                            Does it work on some faces?
                            Are you trying to detect Groups or Components?
                            I'll try to find out how to solve your issue.
                            Best regards,
                            Renderiza
                            • G Offline
                              glro
                              @renderiza said:
                              Best regards,
                              Renderiza
                              sketchup 17
                              it works in some circonstances
                              trying to detect components
                              here is the example that fails
                              platform
                              top view
                              top view
                              "Error: #<RangeError: float Inf out of range of integer>
                              C:/Users/.../SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'"
                              now i admit this is not a usual case
                              most of the time it works pretty well
                                renderiza
                                Now that I have your SketchUp model I am receiving the error you mentioned. I'll work on fixing it soon.
                                Renderiza
                                  renderiza
                                  Try to download the extension again... It should say 'iSelect v2.0.2.rbz' and hopefully the problem you were having is now fixed. Please let me know if it works.
                                  Thanks,
                                  Renderiza
                                  • G Offline
                                    glro
                                    before iselectafter iselect
                                    no error message
                                    and i noticed the progressbar
                                    it is slower but more efficient
                                    thank you
                                      renderiza
                                      best regards,
                                      Renderiza
                                      • E Offline
                                        Einstein
                                        Hi!
                                        I visited your webpage to buy iSelect but when I click BUY NOW, there pops a message: "Oops! It looks like your trial has expired. Please upgrade to continue". I don't understand it - what should I upgrade?
                                          renderiza
                                          @einstein said:
                                          Hi!
                                          Sorry for the inconvenience please go here instead...
                                          https://sellfy.com/p/9upS/
                                          • E Offline
                                            Einstein
                                            I assume the license in for 1 PC only?
                                            • 2 / 3
