    [Extension][$] iSelect
    54 Posts 20 Posters 27.1k Views 20 Watching
      Seems there is a glitch! 😉
      Each 3d block is a group! I select in side view!
      Seems don't works when I all select 1 or all select 2 from left to right or right to lerft! 😲
      All stay selected after click the black eye!(in perspective or parallal projection) 😮
      v6.skp
        glro
        @renderiza said:
        [pre:1w1z3q12]Authors:: Renderiza
        Plugin Name:: iSelect
        Version:: 1.0.1
        Date:: 11/6/2013
        Cost:: Free[/pre:1w1z3q12]
        iSelect v1.0.1 is now available for download.
        http://jroot.sketchucation.com/pluginrepo/image/RND_iSelect_v1.0.0.png
        %(#909090)[What is new:
        • Group & Component selection is fixed
        • Context Menu Added (right click > iSelect)
        • Add keyboard shortcut
        How to set keyboard shortcut:
        Window > Preference > Shortcuts > Function = Edit/Item/iSelect > Add Shortcut
        Thanks for Feedback! 👍]
        i use Iselect 1.0.1 to select components, but sometimes i forget to clic on the plugin button after selecting to filter them
        i wouldn't forget if the filtering was automatic after selection
        so would it be possible modify the order of operations, and embed your plugin in a "filtered selection" tool:
        you click on the button corresponding to "filtered selection"
        you select
        and only then "iselect" is launched to filter the selection
        i tried to add some lines of code to yours to do that, but after calling the native select tool, everything stops ...
        • danchoD Offline
          dancho
          does someone use it under SKP 2015. I can't get it to work 😒
          • E Offline
            Einstein
            Hi!
            As you can see in the attachment, it also deselects some of the front, visible faces. The problem appears when softened edges come into play.
            I also told this in Extension Warehouse.
              glro
              @renderiza said:
              I have updated the code of 'iSelect' and the new version 2.0.0 is available at the following link...
              Also, I'll appreciate more feedback so I can improve iSelect even more.
              Note: I am charging a small fee for the plugin to help me spend more time making SketchUp Extensions.
              best regards,
              Renderiza
              i tried version 2
              still have problems
              Error: #<RangeError: float Inf out of range of integer>
              C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'
              selection is not filtered
                glro
                @renderiza said:
                best regards,
                Renderiza
                something is missing?
                content 1
                content 2
                i don't see the code that is supposed to do the job
                • renderizaR Offline
                  renderiza
                  Can you provide an attachment of the SketchUp model you are trying to use?
                  What version of SketchUp are you using?
                  Can you install the plugin?
                  Does it work on some faces?
                  Are you trying to detect Groups or Components?
                  I'll try to find out how to solve your issue.
                  Best regards,
                  Renderiza
                  [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                    glro
                    @renderiza said:
                    Best regards,
                    Renderiza
                    sketchup 17
                    it works in some circonstances
                    trying to detect components
                    here is the example that fails
                    platform
                    top view
                    top view
                    "Error: #<RangeError: float Inf out of range of integer>
                    C:/Users/.../SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'"
                    now i admit this is not a usual case
                    most of the time it works pretty well
                      renderiza
                      Now that I have your SketchUp model I am receiving the error you mentioned. I'll work on fixing it soon.
                      Renderiza
                        renderiza
                        Try to download the extension again... It should say 'iSelect v2.0.2.rbz' and hopefully the problem you were having is now fixed. Please let me know if it works.
                        Thanks,
                        Renderiza
                          glro
                          before iselectafter iselect
                          no error message
                          and i noticed the progressbar
                          it is slower but more efficient
                          thank you
                            renderiza
                            best regards,
                            Renderiza
                            • E Offline
                              Einstein
                              Hi!
                              I visited your webpage to buy iSelect but when I click BUY NOW, there pops a message: "Oops! It looks like your trial has expired. Please upgrade to continue". I don't understand it - what should I upgrade?
                                renderiza
                                @einstein said:
                                Hi!
                                Sorry for the inconvenience please go here instead...
                                https://sellfy.com/p/9upS/
                                • E Offline
                                  Einstein
                                  I assume the license in for 1 PC only?
                                    renderiza
                                    At the moment I don't require any licensing registration in order to use the plugin.
                                    If you purchase any of my extension you can use them in as many PC's as you see fit.
                                    Also, if I make any updates you will be notified by email with a download button and no further fees is required.
                                    Cheers!
                                    • E Offline
                                      Einstein
                                      Ok, thank you for info.
                                      Can we send you a regular money transfer instead of PayPal payment?
                                        renderiza
                                        My Extensions Store now supports direct payments via credit card without the need to use Paypal.
                                        Thanks for your support!
                                        • E Offline
                                          Einstein
                                          Am I having hallucinations or the minimum fee grows higher and higher every day? I was happy to see this plugin in the very beginning at the price of 3$ but is went up to 10$ O.o
                                          And I was asking about regular money transfer cuz I don't like to pass my card number anywhere. Transfer is a transfer, I'm more ensured about safety of my money.
                                          • jujuJ Offline
                                            juju
                                            a lot of people have this fear, for good reason, but consider that your credit card probably has fraud insurance built into your service fee for it
                                            • 2 / 3
