    [Extension][$] iSelect
    54 Posts 20 Posters 28.5k Views 20 Watching
    • G
      glro
      @renderiza said:
      [pre]Authors:: Renderiza
      [*]Group & Component selection is fixed
      [/color]
      yes
      it works better, thank you...
      there seems to be still some problems
      selection from top
      selection from tp
      this is what is selected from another point of view
      selection before iselect
      after clicking on "iselect" button, some columns remain selected
      as i understand the rule (a component which is not totally visible is excluded from the selection), this shouldn't happen, no?
      selection after iselect
        Seems there is a glitch! 😉
        Each 3d block is a group! I select in side view!
        Seems don't works when I all select 1 or all select 2 from left to right or right to lerft! 😲
        All stay selected after click the black eye!(in perspective or parallal projection) 😮
        v6.skp
        • G
          glro
          @renderiza said:
          [pre:1w1z3q12]Authors:: Renderiza
          Plugin Name:: iSelect
          Version:: 1.0.1
          Date:: 11/6/2013
          Cost:: Free[/pre:1w1z3q12]
          iSelect v1.0.1 is now available for download.
          http://jroot.sketchucation.com/pluginrepo/image/RND_iSelect_v1.0.0.png
          %(#909090)[What is new:
          • Group & Component selection is fixed
          • Context Menu Added (right click > iSelect)
          • Add keyboard shortcut
          How to set keyboard shortcut:
          Window > Preference > Shortcuts > Function = Edit/Item/iSelect > Add Shortcut
          Thanks for Feedback! 👍]
          i use Iselect 1.0.1 to select components, but sometimes i forget to clic on the plugin button after selecting to filter them
          i wouldn't forget if the filtering was automatic after selection
          so would it be possible modify the order of operations, and embed your plugin in a "filtered selection" tool:
          you click on the button corresponding to "filtered selection"
          you select
          and only then "iselect" is launched to filter the selection
          i tried to add some lines of code to yours to do that, but after calling the native select tool, everything stops ...
          • danchoD
            dancho
            does someone use it under SKP 2015. I can't get it to work 😒
            • E
              Einstein
              Hi!
              As you can see in the attachment, it also deselects some of the front, visible faces. The problem appears when softened edges come into play.
              I also told this in Extension Warehouse.
              • G
                glro
                @renderiza said:
                I have updated the code of 'iSelect' and the new version 2.0.0 is available at the following link...
                Also, I'll appreciate more feedback so I can improve iSelect even more.
                Note: I am charging a small fee for the plugin to help me spend more time making SketchUp Extensions.
                best regards,
                Renderiza
                i tried version 2
                still have problems
                Error: #<RangeError: float Inf out of range of integer>
                C:/ProgramData/SketchUp/SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'
                selection is not filtered
                • G
                  glro
                  @renderiza said:
                  best regards,
                  Renderiza
                  something is missing?
                  content 1
                  content 2
                  i don't see the code that is supposed to do the job
                  • renderizaR
                    renderiza
                    Can you provide an attachment of the SketchUp model you are trying to use?
                    What version of SketchUp are you using?
                    Can you install the plugin?
                    Does it work on some faces?
                    Are you trying to detect Groups or Components?
                    I'll try to find out how to solve your issue.
                    Best regards,
                    Renderiza
                    [url=https://www.sketchupcode.com/:z3kqsidd]My Extensions ...[/url:z3kqsidd]
                    • G
                      glro
                      @renderiza said:
                      Best regards,
                      Renderiza
                      sketchup 17
                      it works in some circonstances
                      trying to detect components
                      here is the example that fails
                      platform
                      top view
                      top view
                      "Error: #<RangeError: float Inf out of range of integer>
                      C:/Users/.../SketchUp 2017/SketchUp/Plugins/MiSU_iSelect/MiSU_iSelect_loader.rb:98:in `*'"
                      now i admit this is not a usual case
                      most of the time it works pretty well
                      • renderizaR
                        renderiza
                        Now that I have your SketchUp model I am receiving the error you mentioned. I'll work on fixing it soon.
                        Renderiza
                        • renderizaR
                          renderiza
                          Try to download the extension again... It should say 'iSelect v2.0.2.rbz' and hopefully the problem you were having is now fixed. Please let me know if it works.
                          Thanks,
                          Renderiza
                          • G
                            glro
                            before iselectafter iselect
                            no error message
                            and i noticed the progressbar
                            it is slower but more efficient
                            thank you
                            • renderizaR
                              renderiza
                              best regards,
                              Renderiza
                              • E
                                Einstein
                                Hi!
                                I visited your webpage to buy iSelect but when I click BUY NOW, there pops a message: "Oops! It looks like your trial has expired. Please upgrade to continue". I don't understand it - what should I upgrade?
                                • renderizaR
                                  renderiza
                                  @einstein said:
                                  Hi!
                                  Sorry for the inconvenience please go here instead...
                                  https://sellfy.com/p/9upS/
                                  • E
                                    Einstein
                                    I assume the license in for 1 PC only?
                                    • renderizaR
                                      renderiza
                                      At the moment I don't require any licensing registration in order to use the plugin.
                                      If you purchase any of my extension you can use them in as many PC's as you see fit.
                                      Also, if I make any updates you will be notified by email with a download button and no further fees is required.
                                      Cheers!
                                      • E
                                        Einstein
                                        Ok, thank you for info.
                                        Can we send you a regular money transfer instead of PayPal payment?
                                        • renderizaR
                                          renderiza
                                          My Extensions Store now supports direct payments via credit card without the need to use Paypal.
                                          Thanks for your support!
                                          • E
                                            Einstein
                                            Am I having hallucinations or the minimum fee grows higher and higher every day? I was happy to see this plugin in the very beginning at the price of 3$ but is went up to 10$ O.o
                                            And I was asking about regular money transfer cuz I don't like to pass my card number anywhere. Transfer is a transfer, I'm more ensured about safety of my money.
                                            • 2 / 3
