    Help drawing a toilet seat
    14 Posts 6 Posters 4.1k Views 6 Watching
    • U
      ukchoiceshops
      Hi Everybody,
      I am fairly new to Sketchup and need to draw a toilet seat, I am struggling to get the correct curves drawn as they seem to be irregular curves and tried using Bezier plugin and this doesn't seem to help.
      See attachment of the seat
      Any suggestions I would be grateful as i'm totally stuck now.
      Photo of seat
      • cottyC
        cotty
        Line and arc tool will help you... see attachment.
        toilet.skp
        my SketchUp gallery
        • U
          ukchoiceshops
          Many thanks for the reply I have picked up a couple of tips from the document.
          It still doesnt really answer my question about the curves being irregular.
          the arc tool is good for a regular arc but say the arc is irregular how do i overcome this.
          Thanks Again
          • BoxB
            Understanding how to use the bezier tools will help with Complex curves.
            Here is a very basic use.
            [screenr:3msz2mya]UF4H[/screenr:3msz2mya]
            • S
              spreadcore
              Is this what you want?
              I just used the Bezier plugin and a couple of straight lines, traced half the seat, copied and flipped it for the other half
              http://s5.postimg.org/qkup8wurr/seat.jpg
              http://s5.postimg.org/4abfmomvb/seat2.jpg
              • U
                ukchoiceshops
                Thanks for your help!!!! 😍
                • U
                  ukchoiceshops
                  What is this plugin called as i cant seem to find it?
                  • massimoM
                    massimo Moderator
                    404 Not Found
                    (sketchucation.com)
                    • BoxB
                      I'm a little confused, as always, the only plugin mentioned anywhere in the thread is Bezier. You mentioned trying it yourself in your original post, which is why I did the little vid to show you how it works. It is the one Massimo linked to above. I'd be interested to know if it was another plugin you mentioned in your original?
                      • jeff hammondJ
                        jeff hammond
                        google had a bezier plugin.. thomthom updated it a while back.. not sure what's different in the current version but it appears to have been updated this year:
                        ERROR: The request could not be satisfied
                        (extensions.sketchup.com)
                        dotdotdot
                        • BoxB
                          Cheers Jeff, looks like it behaves the same way. I must admit I have never looked in the Extensions warehouse after my first exploratory visit.
                          • U
                            ukchoiceshops
                            thanks for the help. Is there a way of changing the amount of segments used on this tool?
                            • BoxB
                              Yes there are several ways, but the most simple is to type the number you want before finishing with the tool.
                              Like most tools you can simply type 60s and hit enter and it will have 60 sides/segments.
                              The most obvious way to see this work is to draw a circle, then before doing anything else or trying to click in any boxes, just type 5 s enter and your default 24 sided circle will change to a 5 sided circle.
                              • U
                                ukchoiceshops
                                😍 Thanks
