    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 309.6k Views 110 Watching
    • jiminy-billy-bobJ Offline
      jiminy-billy-bob
      @tig said:
      With the new authors' area once you start editing your entry it becomes 'unpublished'.
      After updating anything you must click the big button near the top to [re]publish it...
      Go back in and do that, and it should reappear in the listings again...
      Uh, I did, but I guess I modified something else afterward.
      It should be fine now.
      • wind-borneW Offline
        wind-borne
        @jiminy-billy-bob said:
        @bimbachi said:
        I have a problem :
        • when adding keyshortcut to LayerPanel tool palet it adds shortcut to SketchucationPluginStore tool palet this same shortcut
        • and as result to use of shortcut, command opens SketchucationPluginStore tool palet!
        Weird, it works fine for me on windows. Can another mac user confirm this?
        What happens if you disable SCtools?
        @bimbachi said:
        question:
        is it possibul that LayerPanel window position would be kept as last open location on the screen? ❓
        I haven't figured how to do that on Mac, it works fine on windows...
        I am assuming what you really want is a shortcut to the layers panel itself and not the toolbar(Palette) icon.
        Within SU shortcuts you can open layer panel window in Window menu but it won't toggle.
        The most functional setup is in System Preferences as you can toggle window with shortcut. You do need to restart after setting or else merely toggles icon.
        "To read between the lines was easier than to follow the text."OSX 10.11.6
        %(#BF80BF)[SU 8 pro
        • JQLJ Offline
          JQL
          @jql said:
          I have a minor issue for you here. Win 7 SU 2014.
          Whow, this is weird. Does this happen in the same file that was previously causing you issues? Do you know how to reproduce this?
          It happened in the same file, I don't know how to reproduce it but it happened more than once. I will work on that same file this week so I'll let you know if anything strange happens.
          Thanks again and best regards,
          JQL
          www.casca.pt
          Visit us on facebook!
          • F Offline
            fountainhead
            Not sure if this is an intended function or not, but I accidently discovered today that holding down 'control' and scrolling causes the whole menu system to resize...that was unexpected, and very helpful. I can double the number of layers visible on the screen. Has this functionality always been there?
            • F Offline
              fountainhead
              Okay, nevermind. Did some looking, and apparently I've been living in the dark ages regarding control + mouse scroll functionality for about a zillion things. 😳
              • G Offline
                greatoe
                2 issues on Mac
                sorry I don't know if these issues been posted before ...
                1. the panel won't remember its on-screen location
                  everytime i drag the panel to somewhere other to another position, most of the time the 2nd screen, after I close the panel and open it again, it will return to its original position.
                  this also happens when SketchUp restarts.
                2. color picker does not work.
                Mac OS X 10.9.2
                SU2014
                • sallyS Offline
                  sally
                  Hello,
                  this looks great but I'm not sure if it is compatible for a Mac, it looks like people have tried it, but it does state on the download page that it is for Windows. Will it cause me any problems if I try it? have any Mac users tried it, any ideas gratefully received.
                  Thanks.
                    jiminy-billy-bob
                    It is OSX compatible, though some minor bugs remain. You should try it.
                    Where do you see it being windows only?
                    • sallyS Offline
                      sally
                      Hi Jiminy,
                      thanks for your speedy response, whilst looking for where it said it was for "windows", I realise I was being very dim!! I saw usage window layers panel and my brain made it mean usage for Windows!
                      I'll give it a try, it looks great. I'll let you know if I have any problems. All the best, Sally
                        jiminy-billy-bob
                        New version 1.1.0 !
                        Introducing layer states :
                        [screenr:2lwo1pas]PWgN[/screenr:2lwo1pas]
                        It works like Photoshop's "layer comps". I didn't keep the "comp" name, as in Sketchup it usually means "components".
                        Changelog :
                        • Added layer "states" (with new dialog). States allows to save snapshots of the current layers visibility, and restore them later.
                        • Fixed several bugs
                        Download in the plugin store !
                        • I Offline
                          ivreich
                          Have just downloaded the new version of Layers Panel (1.1.0) and I'm getting an error message when I try to create a new group or layer. Error message attached.
                          Also, I'm having trouble saving layer states. When I save and close a model, all the layer states come up empty again when I reopen it.
                          Once again, thanks for the great plugin...despite being a work in progress, it's already made it to the top of my list of most used plugins.
                          Keep up the awesome work!
                          Cheers
                          Joel
                          Error mesage when trying to create new layer or layer group
                            jiminy-billy-bob
                            Does it happen in every file? Even a brand new one?
                              chris87
                              Crash when opening sketchup 8 pro !
                                jiminy-billy-bob
                                I'll need a little more details if you want me to help you...
                                  chris87
                                  With your plugin, Sketchup 8 Pro (32 bits Windows 7) doesn't start correctly and a bug splat was produced.
                                  If i remove your plugin, all is OK... and sketchup starts correctly !
                                  Best regards
                                    jiminy-billy-bob
                                    Any error message before it crashes?
                                      chris87
                                      No it crashes just after the new Layers panel Tool-box appears on screen..
                                        jiminy-billy-bob
                                        Could you try with only Layers Panel, and no other plugin?
                                        • JQLJ Offline
                                          JQL
                                          Jiminy,
                                          I've told you before of a file of mine were from time to time I loose all layer groups I created before.
                                          I lost them again and with the latest version of the plugin I can't create new layer groups so I can correct the model.
                                          Something's funky and I don't know what.
                                          The model is 83mb, with a lot of scenes and layers for each scene, so I can create document drawings for construction in Layout. It's heavy in terms of size and organization but it's an example of what we do at our office and why your plugin would be so handy.
                                          I can send you the model, if you want but not through here.
                                          Best regards and thanks,
                                          JQL
                                          www.casca.pt
                                            jiminy-billy-bob
                                            That would be useful. Maybe by PM or email?
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
