    [Plugin] Layers Panel 1.2.1
    673 Posts 110 Posters 322.0k Views 110 Watching
    • icedkaszI Offline
      icedkasz
      I'm hoping to add this extension to my toolset, but I'm having some issues (see attached image). It's very strange.
      If I open up Sketchup2014 first, then click File > Open and find my model, it works just fine.
      If I open the file directly from my windows explorer (locating sketchup\models\model.skp and double clicking it), I get the error shown.
      For some reason, opening the file directly causes problems.
      I found a way around it, though: if I open up Sketchup2014, then IMPORT my model.skp, it works fine. I can save it as model-2.skp, close sketchhup, then open model-2.skp directly, and it continues to work just fine. Very strange. This is SORT of a workaround, but if I try to open any of my other dozens of sketchup files directly, I get the error message. I've tried deleting the files from my Roaming folder, then reinstalling. No luck. Any advise?
      Also as a secondary question, I'll have multiple people using this extension (if I can get it working). We'll be accessing the file from a shared server. If person A adds a Layers Panel group to the model, then saves and quits, can person B open up the model and find that group? Is Layers Panel adding metadata to the model or something?
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        icedkasz > Your first issue has been discussed many times on this thread. It's a Sketchup issue, I can't do anything about it. We need to wait for Trimble to fix it.
        As for your second question: Yes, all the data is stored within the file, so you can give it to whoever you want, and they'll see all you groups etc.
          bimbachi
          I have a problem :
          • when adding keyshortcut to LayerPanel tool palet it adds shortcut to SketchucationPluginStore tool palet this same shortcut
          • and as result to use of shortcut, command opens SketchucationPluginStore tool palet!
            bimbachi
            question:
            is it possibul that LayerPanel window position would be kept as last open location on the screen? ❓
              jiminy-billy-bob
              @bimbachi said:
              I have a problem :
              Weird, it works fine for me on windows. Can another mac user confirm this?
              What happens if you disable SCtools?
              @bimbachi said:
              question:
              I haven't figured how to do that on Mac, it works fine on windows...
                jiminy-billy-bob
                New version 1.0.6 !
                Changelog :
                • Improved "add layer" menu (Hold-down the add layer button), based on Jim's great "Add layer" plugin
                • Fixed "Win32api" error when opening a file from a different drive than sketchup's. (Thanks to Dan Rathbun and TIG)
                • Fixed layer colors vanishing when switching scenes
                Download in the plugin store !
                Credit goes to Jim for the original "Add layer" UI idea : http://sketchucation.com/plugin/832-jf_add_layer
                Thanks to him for allowing me to embed it in Layers Panel
                  Jim
                  Seems like you un-published it because it does not show up in the Plugin Store.
                    With the new authors' area once you start editing your entry it becomes 'unpublished'.
                    After updating anything you must click the big button near the top to [re]publish it...
                    Go back in and do that, and it should reappear in the listings again...
                      jiminy-billy-bob
                      Uh, I did, but I guess I modified something else afterward.
                      It should be fine now.
                      • wind-borneW Offline
                        wind-borne
                        @jiminy-billy-bob said:
                        @bimbachi said:
                        I have a problem :
                        @bimbachi said:
                        question:
                        I am assuming what you really want is a shortcut to the layers panel itself and not the toolbar(Palette) icon.
                        Within SU shortcuts you can open layer panel window in Window menu but it won't toggle.
                        The most functional setup is in System Preferences as you can toggle window with shortcut. You do need to restart after setting or else merely toggles icon.
                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                        %(#BF80BF)[SU 8 pro
                        • JQLJ Offline
                          JQL
                          @jql said:
                          I have a minor issue for you here. Win 7 SU 2014.
                          Whow, this is weird. Does this happen in the same file that was previously causing you issues? Do you know how to reproduce this?
                          It happened in the same file, I don't know how to reproduce it but it happened more than once. I will work on that same file this week so I'll let you know if anything strange happens.
                          Thanks again and best regards,
                          JQL
                          www.casca.pt
                          Visit us on facebook!
                          • F Offline
                            fountainhead
                            Not sure if this is an intended function or not, but I accidently discovered today that holding down 'control' and scrolling causes the whole menu system to resize...that was unexpected, and very helpful. I can double the number of layers visible on the screen. Has this functionality always been there?
                            • F Offline
                              fountainhead
                              Okay, nevermind. Did some looking, and apparently I've been living in the dark ages regarding control + mouse scroll functionality for about a zillion things. 😳
                                greatoe
                                2 issues on Mac
                                sorry I don't know if these issues been posted before ...
                                1. the panel won't remember its on-screen location
                                  everytime i drag the panel to somewhere other to another position, most of the time the 2nd screen, after I close the panel and open it again, it will return to its original position.
                                  this also happens when SketchUp restarts.
                                2. color picker does not work.
                                Mac OS X 10.9.2
                                SU2014
                                • sallyS Offline
                                  sally
                                  Hello,
                                  this looks great but I'm not sure if it is compatible for a Mac, it looks like people have tried it, but it does state on the download page that it is for Windows. Will it cause me any problems if I try it? have any Mac users tried it, any ideas gratefully received.
                                  Thanks.
                                    jiminy-billy-bob
                                    It is OSX compatible, though some minor bugs remain. You should try it.
                                    Where do you see it being windows only?
                                    • sallyS Offline
                                      sally
                                      Hi Jiminy,
                                      thanks for your speedy response, whilst looking for where it said it was for "windows", I realise I was being very dim!! I saw usage window layers panel and my brain made it mean usage for Windows!
                                      I'll give it a try, it looks great. I'll let you know if I have any problems. All the best, Sally
                                        jiminy-billy-bob
                                        New version 1.1.0 !
                                        Introducing layer states :
                                        [screenr:2lwo1pas]PWgN[/screenr:2lwo1pas]
                                        It works like Photoshop's "layer comps". I didn't keep the "comp" name, as in Sketchup it usually means "components".
                                        Changelog :
                                        • Added layer "states" (with new dialog). States allows to save snapshots of the current layers visibility, and restore them later.
                                        • Fixed several bugs
                                        • I Offline
                                          ivreich
                                          Have just downloaded the new version of Layers Panel (1.1.0) and I'm getting an error message when I try to create a new group or layer. Error message attached.
                                          Also, I'm having trouble saving layer states. When I save and close a model, all the layer states come up empty again when I reopen it.
                                          Once again, thanks for the great plugin...despite being a work in progress, it's already made it to the top of my list of most used plugins.
                                          Keep up the awesome work!
                                          Cheers
                                          Joel
                                          Error mesage when trying to create new layer or layer group
                                            jiminy-billy-bob
                                            Does it happen in every file? Even a brand new one?
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 33
                                            • 34
                                            • 26 / 34
