    HELP! Blue Render Vray
    renderpluginsextensions
    13 Posts 8 Posters 23.6k Views 8 Watching
      louchap
      Hi all,
      does anyone know why my bird-eye views keep turning out blue? in vray?
      any help gratefully received
      Thanks Louise
        Just a stab in the dark since this wouldn't be specific to Vray but It looks as if your white walls are reflecting the sky color. Change the color of the sky and you should change the color of the reflection.
          louchap
          tried changing the sky colour but has no effect! any other ideas?
            Generally when I do renders I don't have the model floating in space as you have here. I draw a "set" with a floor, walls and ceiling. This helps to keep light in and allows me to control reflections on surfaces in my model. I do that for anything from a small piece of furniture to an entire house. Maybe give it a try.
            http://farm9.staticflickr.com/8519/8460670489_6bdf323696_c.jpg
            • andybotA Offline
              andybot
              one solution would be to turn off the sun/sky and rely only on GI (global illumination)
              Go to your Vray Options:
              1. Make sure "Default lights" is not checked in your "Global switches" settings
              2. In the "Environment" settings - click on the blue "M" next to "GI (skylight)" and when you bring up the texture options, change the type from "TexSky" to "None"
              3. Then adjust your "GI" number higher from the "1.0" value to something like 15.0 so you get enough light on your scene.
              4. if you have a lot of reflective surfaces, you might try changing your "Environment" --> "reflection" settings to no texture, and give it a neutral gray color instead of black.
              • dkendigD Offline
                dkendig
                you can also change the white balance for the physical camera to be a blueish color, which will cancel out the blue contribution from the texsky
                Devin Kendig
                Developer
                • V Offline
                  valerostudio
                  There is 2 ways to approach this type of rendering.
                  1. Is to do as suggested above by Andy and just set your GI to a white color. This will essentially remove the casted shadows and just render the plan with a ambient light.
                  2. The other way, which makes for a real nice rendering is to place a ceiling plane on your model. Use a SketchUp 2-sided material in V-Ray and make the front face (should be facing into the plan) a white color and make the back face a material that is 100% transparent. Then you want to add some interior lights by using IES or spots and some planar lights at your window openings, and then render the view. Essentially, what happens is that V-Ray renders with no sun flooding into the room from the hole in the ceiling, but keeps it transparent because the face that is facing the camera is 100% clear.
                  Give it a try.
                  • StinkieS Offline
                    Stinkie
                    Or ... http://tricks.onigo.net/guides/2005/08/remove-color-cast-step-by-step.html
                      rspierenburg
                      Or just remove the blueish color cast in post processing.
                        louchap
                        changing the GI colour seems to work, thanks all!!
                        • andybotA Offline
                          andybot
                          I believe that is what TomDC just posted. However, that tutorial is more confusing than helpful imo. All you need to do is open up curves, select the gray dropper, and wherever you click, it will set that area as the neutral tone.
                          • dkendigD Offline
                            dkendig
                            I believe that is essentially what the white balance for the physical camera does
                            Devin Kendig
                            Developer
                            • E Offline
                              emage
                              1. The other way, which makes for a real nice rendering is to place a ceiling plane on your model. Use a SketchUp 2-sided material in V-Ray and make the front face (should be facing into the plan) a white color and make the back face a material that is 100% transparent. Then you want to add some interior lights by using IES or spots and some planar lights at your window openings, and then render the view. Essentially, what happens is that V-Ray renders with no sun flooding into the room from the hole in the ceiling, but keeps it transparent because the face that is facing the camera is 100% clear.
                              Give it a try.
