    Anyone else been seeing messed up smoothed/soft edges?
    13 Posts 5 Posters 6.0k Views 5 Watching
    • WillPittengerW Offline
      WillPittenger
      It seems that every now and then, SketchUp gets confused about which edges are soft/smoothed and which aren't. This seems to be triggered most often by Intersect Faces (on selected faces only even when the edges in question aren't on interesting faces) and grouping/ungrouping faces with smoothed/soft edges.
      However, I think it also happens when complex components are inside an even more complex model. My parent model is at 54 megs. If I edit these components direct, the edges are correct. But if I then import them into my parent model, it has troubles.
      • jeff hammondJ Offline
        jeff hammond
        it's possible you have invalid geometry in one model then when you import it into a new model, it's fixed because you have the preference setting 'auto fix problems when they're found' ticked.
        but that just one of a ton of possibilities.. you're going to have to be more specific/provide examples in order to get some help directly related to what you're seeing.
        dotdotdot
          WillPittenger
          I turned that off a while back. I always want to know ahead of time when it thinks it found something. And it doesn't alert.
          Be nice, but so far, it only happens on complex models/components. Plus, the times I listed may not be correct. All I know is that I see errors I have to fix. And spend a [highlight=#ffff80:165g44ow]LOT[/highlight:165g44ow] of time fixing those errors.
          • Rich O BrienR Online
            Well documented and known issue
              WillPittenger
              I don't suppose we might see a fix sometime soon. 😐
                jeff hammond
                Be nice,
                sorry. didn't mean to come off that way.
                i was just confused by your question is all.
                dotdotdot
                  WillPittenger
                  Be nice,
                  Actually, I got misquoted. I believe I was saying that it would be nice to be able to reproduce it in a predictable manner. But I don't really know the circumstances other than certain events "seem" to be involved and it requires a really large complex model.
                    WillPittenger
                    Well, after having spent umpteen hours fixing my model, I can provide more details. I still don't know more about the circumstances that led to the errors. But I can tell you more about the results. Maybe that will help track down the culprit.
                    First, if a non-smooth/soft edge is associated with two (and only two) planar or nearly planar faces, it may be smoothed/softened.
                    Second, suppose you have an area that started out as the output of the sandbox from contours function. In my case, I wanted most of many of my sandbox areas to be mulched. But part of such an area might be too steep. So I then create a nice curve above it that follows where the gradient changes and use the push/pull tool to extrude that through the sandbox area. Intersect faces then creates the dividing line. The key is that some edges will be split by that curve. If the above event unsmoothes/unsoftens one of the fragments from that edge, all the fragments will be affected.
                      jeff hammond
                      haha.. these darn things called words.. always messing me up.. but i see what you were saying now.
                      carry on
                      β˜€
                      dotdotdot
                        There is a nasty bug where selected geometry will have the Soften Edges function applied to it when the SketchUp window becomes unresponsive.
                        Say you have a group selected, you do some operation that takes a while - the SU UI becomes unresponsive. When the operation is done and the UI responds a Soften Edges operation is applied to the selected geometry.
                        I also notice this when I minimize and restore the SU window.
                        For this reason alone I constantly press Ctrl+T to deselect geometry as quickly as possible to avoid soft+smooth properties from being modified by this bug.
                          WillPittenger
                          Well, for my model, that would be a lot of operations. Auto-save being a primary example. You can't live without it. But until 2013 arrived, I was saving as much as I was editing--even with the file living on a SSD. It still takes longer than it should, but is improved. Still, it would be nice if saves could occur in the background. Trouble with the auto-save is that SketchUp just pauses without giving you a chance to deselect things.
                          I also mentioned that ungrouping large groups causes it for the former group contents. You can't deselect the group and still do that operation.
                            Yea, sometimes you cannot avoid that bug from happening. You can undo it though. But you need to catch it right as it happens.
                            • josephkim626J Offline
                              josephkim626
                              was this issue addressed afterwards? I am still seeing it happen.
