    Window's shadow disappears with sunlight
    renderpluginsextensions
    11 Posts 5 Posters 953 Views 5 Watching
      decumano
      As you can see in these pictures: I'd like to have this kind of sunlight on the floor through the window, with a definite perimeter
      But this is the result
      Do you know what's my mistake?
      Thanks!
      • jiminy-billy-bobJ Offline
        jiminy-billy-bob
        Do you have a rectangular light in front of the window ?
        Did you change the sun's size ?
          decumano
          No, there is nothing in front of the window, and I don't remember I changed the sun size, probably I checked something wrong... this is the global switches setting
          Thanks!
          • V Offline
            valerostudio
            Are you loading someone elses visopt? Looks like your GI is probably not even using TexSky. Its probably just set to a GI color. If you want to see the SU sun, you need to have TexSky in your GI slot.
              decumano
              Yes, it's set on texsky
              this is the GI setting
              AAAAAAAAAHHHHHH I need to find the problem!!
              Maybe it's related with the window?
              • N Offline
                nomeradona
                maybe its the setting of your glass in your window
                visit my blog: http://www.nomeradona.blogspot.com
                • N Offline
                  nomeradona
                  wanna render it without the glass. if the shadows appear then the glass window is the problem
                    decumano
                    Nothing....
                    the same effect without glasses
                    So the problem is the sun, which other settings can I post here to find the problem?
                    • chonC Offline
                      chon
                      Hello decumano,
                      1. I don't think you are using the latest version of VRfSU. If not, upgrade to V1.49.01. Previous versions are known to be bugged.
                      2. In the "Global switches" of the options, uncheck "Show GI only" for test :
                      With "Show GI only" checked :
                      With "Show GI only" unchecked :
                      Maybe the issue...
                      SU2019 pro 19.3.253 + VRay 4.00.02 (Next) on Win10-64Bits
                        decumano
                        Great Chon!
                        The problem was the "show GI only" checked
                        This is the result..
                        Now I just need to lower the sunlight power value, and it should be ok.
                        Thank you everibody for your help, another problem solved!
                        • chonC Offline
                          chon
                          πŸ‘ πŸ˜‰
