Window's shadow disappears with sunlight
As you can see in these pictures: I'd like to have this kind of sunlight on the floor through the window, with a definite perimeter
But this is the result
Do you know what's my mistake?
Thanks! -
Do you have a rectangular light in front of the window ?
Did you change the sun's size ? -
No, there is nothing in front of the window, and I don't remember I changed the sun size, probably I checked something wrong... this is the global switches setting
Are you loading someone elses visopt? Looks like your GI is probably not even using TexSky. Its probably just set to a GI color. If you want to see the SU sun, you need to have TexSky in your GI slot.
Yes, it's set on texsky
this is the GI setting
AAAAAAAAAHHHHHH I need to find the problem!!
Maybe it's related with the window? -
maybe its the setting of your glass in your window
wanna render it without the glass. if the shadows appear then the glass window is the problem
Nothing....
the same effect without glasses
So the problem is the sun, which other settings can I post here to find the problem?
Thanks -
Hello decumano,
I don't think you are using the latest version of VRfSU. If not, upgrade to V1.49.01. Previous versions are known to be bugged.
In the "Global switches" of the options, uncheck "Show GI only" for test :
With "Show GI only" checked :
With "Show GI only" unchecked :
Maybe the issue...
Great Chon!
The problem was the "show GI only" checkedThis is the result..
Now I just need to lower the sunlight power value, and it should be ok.
Thank you everibody for your help, another problem solved!
