    VRAY / Rectangle lighting
    renderpluginsextensions
    4 Posts 4 Posters 2.9k Views 4 Watching
    • X
      xianecci
      Hello All,
      I'm having an issue with rectangular lighting. It seems like it should be straightforward correction for some of you; we'll see. I've attached a few screenshots. Basically, I'm confused as to why the single-source light should create such blurry shadows (I've turned off GI & BG and all other sources).
      In fact, the first pass (Irradiance I believe) begins to show crisp shadows as I'd expect. Then, as it moves to the next passes (Light Cache?), the shadows get diffused and misplaced. I thought it was the Bias -- but tinkering with that doesn't seem to help much; I feel as if its something even more basic. I then thought the Glossiness settings for the floor may have caused it but as you can see I've removed the flooring all together.
      Any thoughts?
      Thanks in advance,
      C
      SKUp_wall & cubbies in skup with rectangle light
      VRay_Light Settings
      VRay_Render during first pass
      VRay_Render complete
      • V
        valerostudio
        Seems to me to be your GI settings. Are you using the defaults? Try turning up your light cache subdivs and DMC settings.
        • dcauldwellD
          dcauldwell
          Rectangular lights always create soft shadows, as the light is generated by the whole surface - the bigger the rectangle the 'softer' the shadows.
          You mention a point light source. If that's what you want then you need to use an 'omnilight' or a 'spotlight'
          David
          Sketchup 2017
          (vray 2.00)
          • eidam655E
            eidam655
            dcauldwell - no, that's not the point of his question...
            i would also blame the GI settings (either the LC subdivs or the irradiance map sample settings), could you post a screenshot of those two?
            I'm using SketchUp 2017, V-Ray 3.4
