    SketchUp 2013 Maintenance Release 1
    18 Posts 11 Posters 2.7k Views 11 Watching
    • sketch3d.deS Offline
      sketch3d.de
      available:
      SketchUp:
      • (Windows) Ruby toolbars have been fixed so that they dock in the right place, as opposed to behind other toolbars.
      • (Mac) Dynamic Components Options and Attributes dialogs have been fixed so that they no longer display an empty window.
      • (Mac) Corrected WebDialog.get_element_value to properly support HTML elements.
      LayOut:
      • (Windows) Copying geometry from SketchUp and pasting it into LayOut is supported again.
      Style Builder:
      • (English and French) The Style Name label has been given extra padding to eliminate an overlap with the input box in the Stroke Settings panel.
      • Windows: 13.0.4124
      • Mac OS X: 13.0.4123
      released: 12.06.2013
      Release Notes
      Download
        Some reactive! 😄
        • dereiD Offline
          derei
          Hmm, this is interesting... several more such releases and maybe we can call SU2013 a REAL new SU version ! 💚
          If (at least in part) this is the result of user dissatisfaction expressed here on SketchUcation, then I'm glad that Trimble is listening ! 👍
          DESIGNER AND ARTIST DEREI.UK
          • K Offline
            kwistenbiebel
            Wow, I am impressed with Trimble .
            A maintenance update so quickly after the official 2013 is a very good sign.
            There is hope 😄.
            Now a little more communication skills and they are about to regain confidence with the part of the user base that is grumpy.
            Well done and hopefully more updates to come 😄
            • FrederikF Offline
              Frederik
              +1
              Cheers
              Kim Frederik
              • KrisidiousK Offline
                Krisidious
                Huge sigh of relief...
                By: Kristoff Rand
                  sepo
                  All my missing tool-bars (some of them I could not find even after double clicking trick) are back. 😄
                  • JQLJ Offline
                    JQL
                    Now Trimble... about that even slower outliner...
                    www.casca.pt
                    Visit us on facebook!
                    • P Offline
                      paddyclown
                      oops, since applying the M release, practically every scene tab update results in a bug spalt ! 😞
                      so M is for merde ?
                        I haven't noticed any changes to scene updates with M1. Is it possible some plugin is causing issues? Have you got V-ray installed?
                        • P Offline
                          paddyclown
                          no V ray... it all worked fine until applying M release... (no plugin changes) 😞
                            Try reinstalling/repairing your SketchUp installation.
                            And please complete your profile with the operating system and version you are using. It'll make it easier for others to help you.
                            • P Offline
                              paddyclown
                              ok, for info, windows vista SP 2 and as I said, all worked fine until M
                                If you temporarily disable your plugins, does the crash happen then?
                                  Paddy, it's M1. Short for Maintenance Release 1.
                                  • P Offline
                                    paddyclown
                                    ok, found the culprit... it was an outdated version of TIGs sectioncutface... upgraded to v3.7 of said plugin and all is working again.. thanks folks. (and M is for merde when things start messing up ! 😄)
                                      So my suggestion that was pushed off of a plugin being the culprit turned out to be on the mark. Not fair to blame SketchUp when you're using outdated plugins. 😉 Might be worth checking any other old plugins you moved from your old Plugins folder to the new one to see if they've been updated. Many have been.
                                      • P Offline
                                        paddyclown
                                        😉 yup, my bad. actually, I did update most plugins and unloaded a whole bunch I never used... but it is odd that friday, before M, I was doing fine, hého, mine is not to reason why !
                                        BTW 2013 is otherwise a great improvement & Layout has become usable without driving me back to smoking ! (the previous versions were so slow that I nearly started nicotine again & went back to bricscad instead) & no, I still have the same machine as before, so i imagine that on a super-duper machine with a vavavoom graphics card it would be even better.
                                        thanks
