    SketchUp 2013 Maintenance Release 1
    18 Posts 11 Posters 2.9k Views 11 Watching
    • JQLJ
      JQL
      Now Trimble... about that even slower outliner...
      www.casca.pt
      Visit us on facebook!
      • P
        paddyclown
        oops, since applying the M release, practically every scene tab update results in a bug spalt ! 😞
        so M is for merde ?
          I haven't noticed any changes to scene updates with M1. Is it possible some plugin is causing issues? Have you got V-ray installed?
          • P
            paddyclown
            no V ray... it all worked fine until applying M release... (no plugin changes) 😞
              Try reinstalling/repairing your SketchUp installation.
              And please complete your profile with the operating system and version you are using. It'll make it easier for others to help you.
              • P
                paddyclown
                ok, for info, windows vista SP 2 and as I said, all worked fine until M
                  If you temporarily disable your plugins, does the crash happen then?
                    Paddy, it's M1. Short for Maintenance Release 1.
                    • P
                      paddyclown
                      ok, found the culprit... it was an outdated version of TIGs sectioncutface... upgraded to v3.7 of said plugin and all is working again.. thanks folks. (and M is for merde when things start messing up ! πŸ˜„)
                        So my suggestion that was pushed off of a plugin being the culprit turned out to be on the mark. Not fair to blame SketchUp when you're using outdated plugins. πŸ˜‰ Might be worth checking any other old plugins you moved from your old Plugins folder to the new one to see if they've been updated. Many have been.
                        • P
                          paddyclown
                          πŸ˜‰ yup, my bad. actually, I did update most plugins and unloaded a whole bunch I never used... but it is odd that friday, before M, I was doing fine, hΓ©ho, mine is not to reason why !
                          BTW 2013 is otherwise a great improvement & Layout has become usable without driving me back to smoking ! (the previous versions were so slow that I nearly started nicotine again & went back to bricscad instead) & no, I still have the same machine as before, so i imagine that on a super-duper machine with a vavavoom graphics card it would be even better.
                          thanks
