    SketchUp 2013 Maintenance Release 1
    18 Posts 11 Posters 2.8k Views 11 Watching
      Some reactive! πŸ˜„
      • dereiD Offline
        derei
        Hmm, this is interesting... several more such releases and maybe we can call SU2013 a REAL new SU version ! πŸ’š
        If (at least in part) this is the result of user dissatisfaction expressed here on SketchUcation, then I'm glad that Trimble is listening ! πŸ‘
          kwistenbiebel
          Wow, I am impressed with Trimble .
          A maintenance update so quickly after the official 2013 is a very good sign.
          There is hope πŸ˜„.
          Now a little more communication skills and they are about to regain confidence with the part of the user base that is grumpy.
          Well done and hopefully more updates to come πŸ˜„
          • FrederikF Offline
            Frederik
            +1
            Cheers
            Kim Frederik
            • KrisidiousK Offline
              Krisidious
              β€’ (Windows) Copying geometry from SketchUp and pasting it into LayOut is supported again.
              Huge sigh of relief...
              By: Kristoff Rand
                sepo
                All my missing tool-bars (some of them I could not find even after double clicking trick) are back. πŸ˜„
                • JQLJ Offline
                  JQL
                  Now Trimble... about that even slower outliner...
                  www.casca.pt
                  Visit us on facebook!
                    paddyclown
                    oops, since applying the M release, practically every scene tab update results in a bug spalt ! 😞
                    so M is for merde ?
                      I haven't noticed any changes to scene updates with M1. Is it possible some plugin is causing issues? Have you got V-ray installed?
                        paddyclown
                        no V ray... it all worked fine until applying M release... (no plugin changes) 😞
                          Try reinstalling/repairing your SketchUp installation.
                          And please complete your profile with the operating system and version you are using. It'll make it easier for others to help you.
                            paddyclown
                            ok, for info, windows vista SP 2 and as I said, all worked fine until M
                              If you temporarily disable your plugins, does the crash happen then?
                                Paddy, it's M1. Short for Maintenance Release 1.
                                  paddyclown
                                  ok, found the culprit... it was an outdated version of TIGs sectioncutface... upgraded to v3.7 of said plugin and all is working again.. thanks folks. (and M is for merde when things start messing up ! πŸ˜„)
                                    So my suggestion that was pushed off of a plugin being the culprit turned out to be on the mark. Not fair to blame SketchUp when you're using outdated plugins. πŸ˜‰ Might be worth checking any other old plugins you moved from your old Plugins folder to the new one to see if they've been updated. Many have been.
                                      paddyclown
                                      πŸ˜‰ yup, my bad. actually, I did update most plugins and unloaded a whole bunch I never used... but it is odd that friday, before M, I was doing fine, hΓ©ho, mine is not to reason why !
                                      BTW 2013 is otherwise a great improvement & Layout has become usable without driving me back to smoking ! (the previous versions were so slow that I nearly started nicotine again & went back to bricscad instead) & no, I still have the same machine as before, so i imagine that on a super-duper machine with a vavavoom graphics card it would be even better.
                                      thanks
