    SketchUp 2013 Maintenance Release 1
    18 Posts 11 Posters 3.0k Views 11 Watching
    • K
      kwistenbiebel
      Wow, I am impressed with Trimble .
      A maintenance update so quickly after the official 2013 is a very good sign.
      There is hope πŸ˜„.
      Now a little more communication skills and they are about to regain confidence with the part of the user base that is grumpy.
      Well done and hopefully more updates to come πŸ˜„
      • FrederikF
        Frederik
        +1
        Cheers
        Kim Frederik
        • KrisidiousK
          Krisidious
          β€’ (Windows) Copying geometry from SketchUp and pasting it into LayOut is supported again.
          Huge sigh of relief...
          By: Kristoff Rand
            sepo
            All my missing tool-bars (some of them I could not find even after double clicking trick) are back. πŸ˜„
            • JQLJ
              JQL
              Now Trimble... about that even slower outliner...
              www.casca.pt
              Visit us on facebook!
              • P
                paddyclown
                oops, since applying the M release, practically every scene tab update results in a bug spalt ! 😞
                so M is for merde ?
                  I haven't noticed any changes to scene updates with M1. Is it possible some plugin is causing issues? Have you got V-ray installed?
                  • P
                    paddyclown
                    no V ray... it all worked fine until applying M release... (no plugin changes) 😞
                      Try reinstalling/repairing your SketchUp installation.
                      And please complete your profile with the operating system and version you are using. It'll make it easier for others to help you.
                      • P
                        paddyclown
                        ok, for info, windows vista SP 2 and as I said, all worked fine until M
                          If you temporarily disable your plugins, does the crash happen then?
                            Paddy, it's M1. Short for Maintenance Release 1.
                            • P
                              paddyclown
                              ok, found the culprit... it was an outdated version of TIGs sectioncutface... upgraded to v3.7 of said plugin and all is working again.. thanks folks. (and M is for merde when things start messing up ! πŸ˜„)
                                So my suggestion that was pushed off of a plugin being the culprit turned out to be on the mark. Not fair to blame SketchUp when you're using outdated plugins. πŸ˜‰ Might be worth checking any other old plugins you moved from your old Plugins folder to the new one to see if they've been updated. Many have been.
                                • P
                                  paddyclown
                                  πŸ˜‰ yup, my bad. actually, I did update most plugins and unloaded a whole bunch I never used... but it is odd that friday, before M, I was doing fine, hΓ©ho, mine is not to reason why !
                                  BTW 2013 is otherwise a great improvement & Layout has become usable without driving me back to smoking ! (the previous versions were so slow that I nearly started nicotine again & went back to bricscad instead) & no, I still have the same machine as before, so i imagine that on a super-duper machine with a vavavoom graphics card it would be even better.
                                  thanks
