    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 218.5k Views 79 Watching
    • davids90gtD Offline
      davids90gt
      @krisidious said:
      On SU 2013 Win, I'm getting this error on startup.
      no such file to load -- 3darcstudio/3darcstudiotree.rbs
      Error Loading File 3darcstudiotreeloader.rb
      The file is in the location specified.
      I'm getting this exact same thing. I have full permissions.
      • KrisidiousK Offline
        Krisidious
        I'm not crazy... WooHoo...
        By: Kristoff Rand
        • ppoublanP Offline
          ppoublan
          @archigrafix said:
          @ppoublan said:
          ok I got it.
          Need to publish new version.
          Really strange that ruby code (without SU calls) not interpreted the same way.
          Will fix this today.
          Yours
          Pascal
          Thanx to help Pascal
          I will wait for it πŸ˜‰
          Beta v0.93 published : (should work with SU7, but still to be tested)
          • Fixed call to hue2rgb code incorrectly interpreted by SU7 (inline def usage)
          • Converted skp leaves components to SU7 file format (hope it will work also with SU8)
          • Fix of β€œup” flowers parameter bug
          • Removed the dot at the end of comments between =begin and =end commands that generates errors loading script in some cases
          Can be found here : http://3darcstudio.com/en/downloads-files/sketchup-plugins/206-3d-tree-maker-sketchup-plugin
          Yours
          Pascal
          • ppoublanP Offline
            ppoublan
            I made tests with SU 2013 (free version). Seems to work, so I Will need more info to find the error cause.
            • any other info within message box other than error loading file ?
            • the loader is not scrambled and only few lines (less than 10), if someone else got similar issue when migrating to SU2013 ? Here is the code (I only removed the dots at the end of lines between =begin and =end.
            =begin
            Copyright 2012-2013 3DArcStudio
            All Rights Reserved
            THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
            WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED WARRANTIES OF
            MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
            =end
            require 'sketchup.rb'
            require 'extensions.rb'
            extension = SketchupExtension.new '3DArcStudio Tree Maker', '3darcstudio/3darcstudiotree.rbs'
            extension.creator = 'Pascal Poublan'
            extension.version = '093'
            extension.copyright = '2013, 3D Arc Studio. All rights reserved.'
            extension.description = 'Sketchup Generic Trees Maker'
            Sketchup.register_extension extension, true
            • ppoublanP Offline
              ppoublan
              Dear all,
              Here is a new tree template I like.
              Extract the zip file to the plugins/3darcstudio directory and choose Vine Tree template when creating a tree.
              Yours
              tree maker template to copy to plugin 3darcstudio directory
                Krisidious
                I get the same error in both SU8 and SU2013.
                Could this be a Pro Problem?
                By: Kristoff Rand
                • Alan FraserA Offline
                  Alan Fraser
                  Kris, are you running SU in Administrator mode? You can set the program exe file to do this every time in Properties. I had to do this some time ago when a few of Fredo's scripts were acting up (before he updated the library file)
                  I'm not saying it'll solve the problem, but it's worth a try. I've had that error in the past with other Rubies...infuriating when the 'missing' file is staring you in the face.
                  3D Figures
                  • TIGT Online
                    Check that everyone has FULL permissions to your Plugins folder [and that it trickles down to all subfolders/files etc...]
                    If you have a 'CREATOR OWNER' listed under Security try to remove it...
                    Use the 'Advanced...' options to Edit that...
                    Add yourself [or your 'group'] as the Owner.
                    The only three entries you need are SYSTEM, users-group and admins-group - and perhaps yourself - BUT you should be in the other two groups anyway!
                    You don't really need CREATOR OWNER or Trusted Installer...
                    Have the inherit properties check-box unchecked!
                    That combined with running it as administrator might alleviate these issues... πŸ˜•
                      Krisidious
                      Ok, I deleted Creator Owner and hit all of the permissions again.
                      ran as administrator... same thing.
                      By: Kristoff Rand
                      • massimoM Offline
                        massimo Moderator
                        Do you have the same settings also for "Users"? If not, do the same for that.
                          Krisidious
                          path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
                          File.exist?(path)
                          true
                          Load Path
                          Error: #<NameError: (eval):155: uninitialized constant Path>
                          (eval):155
                          load path
                          Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
                          (eval):155
                          (eval):155
                          By: Kristoff Rand
                            Krisidious
                            yes... have it at the same.
                            By: Kristoff Rand
                              Alan Fraser
                              That looks similar to my Plugins properties...except I have "CREATOR OWNER" on top of SYSTEM; and "Administrators(Alan-PC/Administrators)" underneath it.
                              3D Figures
                              • TIGT Online
                                Remove 'Trusted Installer'.
                                The 'CREATOR OWNER' is optional - but if it inherits permissions from its container, then it might screw up things...
                                Use the minimum number of 'users/groups' that you can get away with...
                                Ensure that they ALL have FULL permissions.
                                Do no 'inherit' any permissions...
                                  Krisidious
                                  Done... Still problem persists...
                                  By: Kristoff Rand
                                  • TIGT Online
                                    What's under the 'Owner' tab ?
                                      Krisidious
                                      By: Kristoff Rand
                                      • TIGT Online
                                        Then you are screwed 😲
                                        I'm out of ideas... πŸ˜’
                                          Krisidious
                                          By: Kristoff Rand
                                            Krisidious
                                            By: Kristoff Rand
                                            • 6
                                            • 7
                                            • 16
                                            • 17
                                            • 5 / 17
