    [Plugin][$] 3D Tree Maker - New version 1.10.14
    322 Posts 79 Posters 247.6k Views 79 Watching
    • Alan FraserA Offline
      Alan Fraser
      Kris, are you running SU in Administrator mode? You can set the program exe file to do this every time in Properties. I had to do this some time ago when a few of Fredo's scripts were acting up (before he updated the library file)
      I'm not saying it'll solve the problem, but it's worth a try. I've had that error in the past with other Rubies...infuriating when the 'missing' file is staring you in the face.
      3D Figures
        Check that everyone has FULL permissions to your Plugins folder [and that it trickles down to all subfolders/files etc...]
        If you have a 'CREATOR OWNER' listed under Security try to remove it...
        Use the 'Advanced...' options to Edit that...
        Add yourself [or your 'group'] as the Owner.
        The only three entries you need are SYSTEM, users-group and admins-group - and perhaps yourself - BUT you should be in the other two groups anyway!
        You don't really need CREATOR OWNER or Trusted Installer...
        Have the inherit properties check-box unchecked!
        That combined with running it as administrator might alleviate these issues... πŸ˜•
        • KrisidiousK Offline
          Krisidious
          Ok, I deleted Creator Owner and hit all of the permissions again.
          ran as administrator... same thing.
          By: Kristoff Rand
          • massimoM Offline
            massimo Moderator
            Do you have the same settings also for "Users"? If not, do the same for that.
              Krisidious
              path='C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs'
              File.exist?(path)
              true
              Load Path
              Error: #<NameError: (eval):155: uninitialized constant Path>
              (eval):155
              load path
              Error: #<SyntaxError: (eval):155:in load': C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ C:/Program Files (x86)/Sketchup/Sketchup 2013/Plugins/3darcstudio/3darcstudiotree.rbs:1: Invalid char \010' in expression>
              (eval):155
              (eval):155
              By: Kristoff Rand
                Krisidious
                yes... have it at the same.
                By: Kristoff Rand
                  Alan Fraser
                  That looks similar to my Plugins properties...except I have "CREATOR OWNER" on top of SYSTEM; and "Administrators(Alan-PC/Administrators)" underneath it.
                  3D Figures
                    Remove 'Trusted Installer'.
                    The 'CREATOR OWNER' is optional - but if it inherits permissions from its container, then it might screw up things...
                    Use the minimum number of 'users/groups' that you can get away with...
                    Ensure that they ALL have FULL permissions.
                    Do no 'inherit' any permissions...
                      Krisidious
                      Done... Still problem persists...
                      By: Kristoff Rand
                        What's under the 'Owner' tab ?
                          Krisidious
                          By: Kristoff Rand
                            Then you are screwed 😲
                            I'm out of ideas... πŸ˜’
                              Krisidious
                              By: Kristoff Rand
                                Krisidious
                                By: Kristoff Rand
                                  Krisidious
                                  πŸ’­
                                  By: Kristoff Rand
                                    Krisidious
                                    Yes!
                                    It's a conflict.
                                    Removing all plugins from the plugins folder and it works.
                                    Now how can I figure out which one it is...
                                    By: Kristoff Rand
                                    • BoxB Offline
                                      Do the old half half trick, add half of them back, if they work try the other half, when you get a half that doesn't work halve it and repeat until you have the one precious.
                                        Krisidious
                                        I have something running that none of you do... and David does.
                                        David? What do you draw?
                                        By: Kristoff Rand
                                          Krisidious
                                          extensions.rb...
                                          By: Kristoff Rand
                                            Krisidious
                                            Tig says...
                                            As a 'health-check' can I suggest that anyone who thinks they have a mess up looks in their ../Plugins folder for the following .rb files that ought to appear only in their ../Tools folder.
                                            If they are in the wrong folder move them [back] into ../Tools; if they are duplicated then remove the Plugins folder's version.
                                            Depending on your SUp version, and what optional tools you might have, you could have these .rb files...
                                            Which should be in ../Tools if you have them at all...
                                            The bold ones are the base-set for most setups and have been around for several versions...
                                            advancedcameratools
                                            date
                                            **dynamiccomponents**
                                            **extensions**
                                            filmandstage
                                            **langhandler**
                                            make_pano_pm
                                            rational
                                            **sandboxtools**
                                            shadowstringsfix
                                            **sketchup**
                                            SolarNorth
                                            webtextures
                                            Several of these have matching subfolders - e.g. 'Sandbox' within ../Tools too...
                                            If you are in any doubt ask.
                                            Don't delete any duplicated files you find but rather move them into a [new name='disabled'] subfolder so they don't auto-load - then you can always restore them when you've gone wrong πŸ˜’
                                            By: Kristoff Rand
                                            • 16
                                            • 17
                                            • 5 / 17
